跳转到主内容
Released in 2005. Model number: PP11L, Imput: 19.5V ~ 4.62A.
15 个问题 查看全部
Can I replace the 1024x768 screen with a 1400x1050 screen alone?
Hi, I have a Dell Latitude D610 for which I have no use, personally, but it is not yet in condition to sell as it has a broken screen. Can I replace the 1024x768 screen in it with one that is 1400x1050 without having to replace anything else in it (i.e. inverter, CCFL) or do I need the whole assembly?
Reason I ask is that the display alone can be anywhere from $40-60 on eBay while the whole assembly can be $100+, and I'm not sure that I need the whole assembly yet. I'm fairly sure the inverter works OK, as the small corner of the screen that does work works fine the whole time.
Ultimately, will I be able to pay $50-70 to get an upgraded, working display and turn this into a sellable laptop? I've gone through and cleaned up the Windows installation so that it boots up fairly quickly and it's ready for somebody else to pick up and start using as soon as I've got the screen in working condition.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
If you're sure it's a broken screen that's all you need to replace, you may want to check and see if the display cable is loose, but if it's a broken LCD even if the dimensions are different you can still use the same inverter, etc.
这个答案有帮助吗?
得分 1
1条评论:
Thanks; yes, the LCD itself is broken (i.e. I can see the liquid coming out of it, and most of the screen is garbled lines and such) although there was a tiny few square inches of screen that were visible enough for me to switch the control panel to display on the external monitor
完成的
添加一条评论
I believe that a higher resolution display would have a wider ribbon cable, and not plug into the motherboard.
However, if I'm wrong on that guess, or if a screen the same as the original is used, nothing else should need to be replaced.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
fury 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 2,670
