跳转到主内容
加入维修社区 - 创建账户
2013年9月10日发布的 Apple iPhone 5c 的维修信息和指南。型号:A1532, A1456
How can I fix a keyboard problem?
iPhone 5C keyboard will not type certain letters after screen repair. Everything else works fine except for the keyboard. It wont allow me to use the numbers button. Tried a hard reset. Did not work. What can i do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 13
添加一条评论
6个答案
已选择的解决方案
If a different "known good screen" does the same (a whole batch can be bad), then the issue can be with a chip on the board that controls touch. It would be partially separated from the board, causing some areas of the screen to become unresponsive.
But really must try a new known good screen first, as this is still the first suspect.
这个答案有帮助吗?
得分 4
添加一条评论
最有帮助的答案
Sounds like a faulty digitizer to me, or a poorly seated digitizer connector. Did you do the screen repair yourself, or did you have a repair shop do it?
这个答案有帮助吗?
得分 4
4条评论:
My sreen is smashed but this was happening before i
Smashed it
由完成的
no it was not
由完成的
I had the repair shop to do it.
由完成的
You should tell your shop about it. If a different "known good screen" does the same (a whole batch can be bad), then the issue can be with a chip on the board that controls touch. It would be partially separated from the board, causing some areas of the screen to become unresponsive. But really must try a new known good screen first.
由完成的
添加一条评论
Usually, the problem occurs after a screen has been replaced and the digitizer cable has not been seated properly. You have to ensure the correct sized screws fitted into the correct position. There are four screws holding down the shield that covers the display cables and if you mix them up then your shield and cover will not fit correctly and the cable connectors will move and cause digitizer and screen faults. Uisung #000 screwdriver you can easily remove and refit these screws, if you are unsure the bottom two are the smallest (1.3 mm screws) and then the upper left is slightly larger (1.7 mm screw) and the far right screw is the largest of them all (3.25 mm screw). You can prior to the removal use a coloured marker or pen and colour code the screws to the position they belong to, remember the two lowest screws (1.3 mm screws) are the same size so can be coloured the same. This should help resolve any problems with exchanged screens and cabling to screen faults. Thanks guys
这个答案有帮助吗?
得分 2
添加一条评论
hello,
this is in relation with touchscreen ic chip when everything is all right...
这个答案有帮助吗?
得分 1
添加一条评论
My keyboard is frozen also screen
这个答案有帮助吗?
得分 1
添加一条评论
my iPhone 5s I got the screen repaired and the u and n dose not work on the keybord
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
keldavis5 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 25
总计 31,831
