跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
My phone only charges when its off
Okay so my phone only charges when its off but when it turns on my phone doesn't recognize that its being charged and then it dies. it comes back to life at 4 percent and dies. its not the cord because I've tried it on 2 different phones and it works perfectly fine on the other two. Again my phone only charges when its off but never when its on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 77
24条评论
even i am experiencing the same issue.. pllease give me a suggestion how to get rid of this problem
完成的
i have this exact same problem! i've replaced both the battery and charging port but that hasn't fixed it. seemingly randomly (maybe 1/20 charge attempts) will charge the phone to 100%. most attempts only charge the phone just enough to turn on (at about 3-5%) and then the phone crashes within 10 seconds of booting up. in case it matters mine is a 5S.
update: i just had a successful attempt and out of curiosity i turned the phone off and then back one and when it came back on it was no longer charging.
完成的
I had the exact problem and decided to buy a new charger, which solved the whole problem.
完成的
Solved: Need Apple brand charger
I had the same issue and tried 3 different chargers. Come to find out it was cheap generic chargers. Once I tested with an actually Apple charger it worked.
完成的
Water damage... Same thing happened to my phone- took it to att and apple who said I could get a new phone under warranty however the charging port has damage. They told me it was not something that could be repaired. My phone only charges when it's turned off as well. My screen needs to be entirely black. When I know its about to die (like at 2%) I'll plug it in to the wall charger, and turn on the flashlight and leave it there. The flashlight drains the rest of the battery and the phone will shut down. At that point..leave it! Don't touch any buttons or re-plug the charger back in to make sure you see a battery symbol, that will prevent the phone from charging to 100%. Just trust that it is charging, even without seeing the battery symbol! The screen should be ALL black. I do this when I'm about to sleep..and when I wake up in the AM, unplug the phone and it's at 100%!!!! Before trying this exact method, I could also only get it to turn on to 2% (or 7%) before shutting off.
完成的
显示更多的19条评论
添加一条评论
11个答案
最有帮助的答案
First step is to try another battery. 2nd step is to replace the docking port. One of those should fix your problem
这个答案有帮助吗?
得分 5
9条评论:
thats the worst advice ever DID you seriously tell him to replace a Iphone battery
完成的
@Dean Thompson, absolutely. What do you think is wrong with that answer?
完成的
@Dean , You obviously have no idea what you're talking about Dean and the fact that you wrote "a" iPhone instead of "An" iPhone tells me you're about 12. Go and troll somewhere else.
完成的
While I agree with Dave and I think Dean is a troll, I think you need to check your grammar before pointing the finger. "@Dean , You obviously have no idea what you're talking about Dean". When you put @dean, we already know who the comment is aimed at.
完成的
Dean I have accually fixed this problem myself on a few iPhone 5s with a battery and if that doesn't sort it they try a dock connecter and if neither work it's motherboard issues..
Get your facts correct dean
完成的
显示更多的4条评论
添加一条评论
Before you replace anything, try this Use a toothpick to clean out your iPhone. It might fix your problem.
这个答案有帮助吗?
得分 5
1条评论:
Although I used a toothbrush instead of a toothpick, cleaning the charging port fixed the problem.
完成的
添加一条评论
Please check your serial number here to see if it qualifies for the Battery Replacement Program:
https://ssl.apple.com/support/iphone5-ba...
这个答案有帮助吗?
得分 2
1条评论:
After extensive investigation it turns out to be the battery. My phone was covered by apple warranty and so they replaced the battery and now all is fine.
If you send your phone away to apple remember. To back it up.
完成的
添加一条评论
Dear All,
Fault can be occur due to bad battery for faulty charging IC
Beging trubleshoot with battery replacement,
Here you can find the battery replacement guide.
这个答案有帮助吗?
得分 2
1条评论:
Initially as a short term solution: as soon as the battery reached 4% I immediately switched off the iPhone and let it charge while the phone is off. After an hour or so it definitely reached around mid 60s level.
Later I ended up changing the battery and charging strip and now it's as good as new.
完成的
添加一条评论
I was having the same problem with my iPhone 7. I have had the phone since October pf 2016, and yesterday it stopped charging completely. I turned my phone off and let it charge last night so that it could come all the way up to 100%. I just went into my settings and reset the Network Settings back to default, and it appeared to fix the problem for me. Not saying it will do so for you, but it might. I had even went and bought a new charger. But it didn't charge my phone and would charge my moms. So I knew then it had to be something with my phone. After researching a little, I seen that resetting the network settings back to default could be a trick to fix it and sure enough, it was. Good luck with you.
这个答案有帮助吗?
得分 2
1条评论:
Thank You..!!!! Resetting the network settings fricken worked..!!!! Muah
完成的
添加一条评论
Son's cell did this same thing. Read through all the "didn't work" solutions which didn't for me either.
However, on a goof while it was hovering at 2%, I decided to get into Settings--General--Reset--Reset All Settings. Of course it died mid-reset, but after it came back on & finished, I unplugged & replugged it in while it was still on & it started charging while powered on!
这个答案有帮助吗?
得分 1
2条评论:
I had same problem for a month, today, I reset all of iPhone( erase ), then it began charging needn't to turn it off.
完成的
idk mine refuses to charge,sometimes it charges when i decide to use a power bank
完成的
添加一条评论
I am currently having the same problem with my iPhone 6, but there is no worry. This is a common thing to happen with all iPhones. What I recommend doing is charging the phone until it turns on. Then, even if it shows it is not charging, power your phone OFF, and keep your charger plugged into the phone. I did this at night and when I woke up my iPhone was at 100%. If this didn’t work for you, you can go to apple customer service (online) and talk with a apple tech. They will help you with any problem you have.
这个答案有帮助吗?
得分 1
2条评论:
what about later ? after charged 100% ... whenever you need to charge it again you will turn it off again ?
完成的
i charge my phone until turns on then i power my phone off but he powers on again automatically i power off again and he turns on again automatically he can’t stay on power off while the charger is plugged in !!
完成的
添加一条评论
Your iPhone requires less power to charge while it is off, than it does to charge and run the phone while it is on. The charger you are using is supplying enough amperage to charge the battery while the phone is off. Once the phone turns on, the current draw is too much for the charger to keep up with, so the phone starts draining the battery again. Apple chargers will not have this problem. Switch to a genuine Apple branded charger and see if you continue to have this problem, it is unlikely you will.
这个答案有帮助吗?
得分 0
2条评论:
Okay then I've got 2 Apple chargers and they're 10W USB Power Adapters, before my 5S was charging with both but after updating stopped. Same with other ones like 4S's & 4's. Can you explain this? What's the recommended parameters a usb power adapter should have?
Here is a more detailed description of my adapters:
Model: No:A1357 W010A051
Input: 100~240V ~ 0.45(0.45A) 50-60 Hz Output: 5.1GV -------- 2.1A
完成的
And you checked to make sure that's what you are getting out of them? All I'm trying to do is eliminate the problem that is most likely. Especially considering how few people actually have this problem.
完成的
添加一条评论
Here is how you charge past 5% go to settings> general> Accessiblity >assistive touch on
When your phone turns on keep it on the charger push the assistive touch press device then hold in lock screen until a slide bar comes up slide it and your phone will turn off and continue to charge to turn your phone on unplug your phone and plug it back in (these steps won't let you charge when it is on but will help you get 100% battery when you do charge it turned off)
这个答案有帮助吗?
得分 0
1条评论:
I tried this solution but after powering off he turns on automatically
完成的
添加一条评论
Sounds like a bad u2 ic to me, you can try another battery and charge port, but if that doesn't solve it, its certainly the problem, as I see loads of them
这个答案有帮助吗?
得分 0
添加一条评论
My Iphone 4s it's only charge when I turned it off but no charging symbol
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
alondra candelario 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 87
总计 268,039
