跳转到主内容
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
342 个问题 查看全部
How can I test the Power Supply (voltage values)?
I have an iMac (Model A1311, EMC: 2389) that won't power up properly. I want to test the power supply but cannot find the output voltage values anywhere on the internet.
I would be happy to post a 'technique' article showing people how to access and test the power supply in this model if someone can help me determine their proper output values.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 18
2条评论
Bless you, bless you, bless you both! The link led to a trove of excellent technical material and the diagram you posted is very clear. Thanks! I WILL post a technique article on testing this PSU so that others following in my footsteps will have an easier time.
Thanks again, and may the Valar watch over you! - Valdaquendë
完成的
That would be fantastic and help a lot of others!
完成的
添加一条评论
2个答案
已选择的解决方案
This PDF should give you the pin out: Apple Technician Guide for iMac (21.5-inch, Mid ... - tim.id.au
http://tim.id.au/laptops/apple/imac/imac...
这个答案有帮助吗?
得分 13
10条评论:
Thanks again for that link, mayer; it's probably the biggest, most comprehensive archive of manuals for Apple devices I've ever seen! Apple devices cross my workbench with some frequency but it's been varying degrees of hard to find the manuals needed to work on them.
I should add that the site contains manuals for thousands of other laptop models by many different manufacturers; anyone reading this who has a frequent need for this sort of material will find the site a wonderful trove of information. Thanks again!
完成的
This PDF works to iMac 21,5" Mid 2011 (EMC: 2428)?
完成的
I don't understand the down vote on this.
完成的
@mattgordon see above request for explanation of down vote
完成的
显示更多的5条评论
添加一条评论
Valdaquende, just in case you miss mayer's link
这个答案有帮助吗?
得分 10
2条评论:
Thanks! This pinout was just what I needed. I accepted mayer's answer because it contained the info I needed and TONS of additional information but I wish I could have split the answer between the two of you; both answers were very helpful. Thanks again!
完成的
Valdaquende, that is the proper choice. mayer did answer the question appropriately and I just wanted to augment his answer. Well done.;-)
完成的
添加一条评论
添加你的答案
Valdaquende 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 87
总计 31,539
