跳转到主内容
Part of Nokia's Lumia line of Windows smartphones. Announced July 2013.
35 个问题 查看全部
need to wait 420000 min to use again
hello everyone,
i have replaced my nokia lumia digitizer and now i need to wait a lot of minutes to use it agian, is there a solution to solve this? because i need to wait more than a year right now to use the nokia again,
thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
willem you could try a hard reset as a last resort. You will lose all you apps, games, and files. To do that, hold down the camera button, power button and volume down button at the same time. Once the phone vibrates, let go of the power button but continue to hold down the volume down and camera button for a few more seconds. this should restore your phone to factory settings. Or you can try what is suggested on here. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
2条评论:
Sorry oldturkey03, but I tried your suggestion but it doesn't work, when I tried your suggestion the minutes get higher and higher, can you please give me more suggestion?? PLEASE...
完成的
@bdeth you tried a hard reset as described in my answer? What happened to your phone that this came up?
完成的
添加一条评论
Hello, am Samuel.
I tried the normal factory reset but now my phone wont turn on. It just load and load after that a blue screen with the writing come back online and try again appears on the phone. I cant access the phone now.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
willem 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 4,900
