跳转到主内容
苹果在2003年发布的外置iSight网络摄像头的维修指南和支持。
6 个问题 查看全部
For use in monitoring my front door
I'd like to mount an A1023 iSight Web Camera around my front door and hook it up to my MacPro in my office. I've read that the maximum length for a firewire cable is 10'. Since it will not be carrying a lot of data, I think I can use a much longer cable. Next part of the question concerns cost. Can I make a firewire cable? I've never cut into one. I know I have a box of old BNC cable around and certainly a box of Cat 5 cable. Could I cut a short cable and splice wire in? The iSight has a Firewire 400 and I can use an adapter to get into any of the four Firewire 800 ports on my Mac Pro. I already have an A1023 iSight camera set up for FaceTime.
Or is there a wi-fi device to hook up to the camera to send the signal wirelessly?
This would use a 6 pin to 9 pin connector.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
mayer, above 33 feet (10M) a repeater is recommended. I would try to extend the cable and see how the camera functions without a repeater ($$$) first. Use a six strand cable and connect it using this diagram as guide. I guess EvoCam or Security Spy might be the software to use.
这个答案有帮助吗?
得分 1
3条评论:
I'm also working on an app that uses iBeacon but don't know enough about it yet to know if it could be incorporated.
完成的
iBeacon looks interesting. Let us know if you get it to work for your application.
完成的
This article http://www.macworld.com/article/1029862/... may be of interest to you
完成的
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 2,198
