跳转到主内容
Released in November 2013, this model of the HP 2000 series is the perfect device for those on a budget, but don't want to sacrifice performance.
34 个问题 查看全部
Why is my computer very loud?
My laptop has been running fine since I bought it a few months ago but all of a sudden it has started getting very loud and hot while on. The fans have been running nonstop. Is there anything I can do so that it will quiet down?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Conor Most, you will have to find out why it does that. Check your computer resources and see what the total demand is. Make sure that your laptop has unobstructed airvents. Make sure that those vents are clean. If all that is normal you will have to disassemble your computer and take a look at the Fan. I would replace it for sure. Check the heatsink and assembly and replace the thermal paste. download the service manual from here Page 73 will tell you how to replace all that . Hope this helps, good luck
这个答案有帮助吗?
得分 3
添加一条评论
It's under warranty, let HP fix it or you'll void that warranty!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Conor Most 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 443
