Phone power off alone,and vibrate.
My phone come on for a few min. then power off alone or the option to power off my phone pops up on the screen. when phone power my phone continue to short vibrate. What could be wrong or what should I do?
remove and reinset the battery, press the volume up key, home button and power button simultaneously. you can see recovery console. format the cache partition and select reboot. fault may solve. Note: dont format the flash because your all data will be lost
这个答案有帮助吗?
If my Phone haven't removable battery and Power button not worked .. then what can I do
Rohit, this is about Galaxy note. if you have any trouble with your phone you can ask a question mentioning the model info. we can help you to fix the phone !
I got LG G3 my phone suddenly restart.. with viberation
My phone model samsung one7 pro.Often the phone shutdown and keep vibrating for 20 or more seconds.. Now what can I do to fix the problem?
My phone is realme c15 shutdown itself, the alarm is ringing but it's not opening, what can I do the battery is unremovable.
Jennetta Davis, start by replacing the battery. This will also provide you with a known-good starting point for further trouble shooting. For now, it does sound like a battery issue.
这个答案有帮助吗?
It's not the battery it's the power button:
这个答案有帮助吗?
Pls have not satisfied with galaxy note issue my own keep on restarting over and over till it will drains up the battery i'm tired.
yes, your galaxy note 3 may have a battery issue
____________________________________________________
这个答案有帮助吗?
Samsung galaxy s4
Sometimes all at once the phone will start to vibrate and won't stop , likes it's stuck on vibrate. only way to stop it is to turn it off . Any advice
Thank you !!!!
这个答案有帮助吗?
I have same problum
I press the volume dowen(volume up key is not working) key, home button and power button simultaneously but odin mod appeair thair is downleoding......
Donot trun off target!!
What can i do
这个答案有帮助吗?
I have the same issue with j5.but when I plug charger it continues to vibrat but doesn't on...
dont press vol down....press vol up instead
I have same issue my GT-S5301 phone
@Julia Toutou same also for me
I have oppo A 15 , i am using the phone suddenly it turn off automatic and start vibratng and now it continous vibrating plz tell me what can I do it's not now turn on and not stopping vibrate
i have samsung galaxy note edge.. its working properly but when i switch it off, this phones starts vibrating continuasly , and i cant switch it on with power button, i need to connect to charger then it will be on... what is the probelum in phone , kindly reply
这个答案有帮助吗?
My Galaxy Note 4 suddenly went off while charging on 40%. The screen then displays the charge symbol with no battery indicating that the battery is zero but then it tries booting itself which then vibrates, goes off and shows empty battery level. I thought it was a battery issue so I replaced the battery and it still does the same. It won't boot. keeps indicating empty battery though on other Note 4, my battery shows 100% charged. I can't even enter hard reset mode with the keys because you try and the phone goes off and restarts. No physical damages or what so ever. Only a month old.
my s7 edge phone is vibrating automatically after every hours at 45 mins.I did stop all notifications for apps and stopped vibrate options of phone setting too..still its vibratiing.so now what I should do??
这个答案有帮助吗?
My Galaxy 6 edge is stuck on fab lock on , odin mode, downloading -do not turn off target .__…..
这个答案有帮助吗?
Good day guys, my infinix hot 8 x650b is not displaying, not powering on, but vibrate profusely. The charging port is okay when charging it doesn't display just the charge indicator light. I try the power button+volume down nothing displayed. Please what can I do?
I have a galaxy 5 samsung it constantly vibrates while it is plug in.It shows no battery life ,when i take the battery out it shows power but it just start"s to vibrate again,What should i do.It vibrates and flashes to while it is charging,could it be my battery or my phone,i had my phone now for a few years but i took care of my phone since i had it.
Automatically my phone will vibrated 10 sec and power offed and yet never started.... Samsung
这个答案有帮助吗?
过去的24小时: 7
过去的7天: 46
过去的30天: 241
总计 74,162
My phone Micromax canvas colours 2 is switched off and is vibrating continuously. I have kept it near a bottle in the storage of my scooter. What to do ? It's screen is also coming white from sides.
由 Devansh Khare 完成的
