跳转到主内容
加入维修社区 - 创建账户
2012 年,Sony Entertainment 宣布将发布其 2006 年推出的 Playstation 3 游戏主机的全新版本。这款新主机被称为 Playstation 3 Super Slim,型号为 CECH-4000。PlayStation 3 Super Slim (CECH400x) 是 Sony Computer Entertainment 生产的第三款 PS3 视频游戏主机。它于 2012 年 10 月 25 日发布。
ps3 wont read disk
hi everyone my ps3 super slim wont read any disk when i put a disk in it makes a few click sounds then like a engine rev, i can tell i spins the disk i put in but not 360 what Im saying is it spins ones then stops and i does not show that the disk is in i do not know why its doing this but two days ago it work fine then today i turn it on and what do you know. oh and its only two years old i got it in late 2012 everything else works on the ps3 i just hate to buy a new one because im high ranks online in most of my games gta5 bf4 gt6 bo2 ect
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 34
11条评论
Well i been having my ps3 super slim for 6 months and two day ago i try to play gta online and my system said update to 4.76 .....so i did it and now it wont read any of my games what can i do to fix it.
由完成的 分享
My console Can play PS1 Games however... still wont play other stuff like PS3 or 2 and no Blu-Rays
由完成的 分享
well my system made the clicking sounds but it spinned but when the next day started i turned it on and now my system stops playing games completely
由完成的 分享
I'm having same problem. I had to buy a new ps3 bc the one I got when they first came out tore up. My new one is a few years old. It just reads sometimes then not read sometimes.makes the clicking noise. But u can fix it by turning the lens a certain way. Just I'm not smart enough to do that :( don't worry if u buy a new ps3 it won't affect trophys any online ranks etc. Bc your online stuff is always there as long as u sign in with the same name. It has something to do with the lens. But if u do want to buy a new one u can probably get one round 20 bucks at yard sales or pawn shops. There's some games I need to finish. And play and my ps3 will not read discs. Also on mw3 it would freeze all the time after 2 hours of ejecting and reinstating the disc so it would read. Never been so mad in all my life. Cd players DVD players do the same thing
由完成的 分享
Won't load a game. what Is wrong with it.
由完成的 分享
显示更多的6条评论
添加一条评论
4个答案
已选择的解决方案
May just need the laser replaced. Follow this video guide found here
这个答案有帮助吗?
得分 2
9条评论:
bruh plzzzzzzz tell me how to fix the ps3 and im a high rank on gta5 im rank 289 plzzzzzzz help
由完成的 分享
Plzz Help Sleeping Dogs Anit Working AND Bo2 Im mAster lvl Help
由完成的 分享
My ps3 super slim wont load my games all i hear is a clicking sound. If i restore it will that solve this problem??????
由完成的 分享
How can I make it read my games again
由完成的 分享
I got a super slim but it wont read any discs what do i do?
由完成的 分享
显示更多的4条评论
添加一条评论
最有帮助的答案
My name is Stephen.w and I'm here to help you. It's not the disc or the laser it's the disc stopper what your gonna need to do is remove the back panel and by the door of your disc cover you'll see a little plastic wing slide the cover back and there's your problem lift up the little tab and insert a small pick or something what I did was I got a small plastic pick and cut it in a angle and made one side big and the other small and dipped it in super glue and placed it in and that's it disc spins and now you can play. Now remember if wemon don't find you handsome they'll at least find you handy lol P.S for the PS3 super slim
这个答案有帮助吗?
得分 3
9条评论:
Please help mine won't spin I don't no how to do that
由完成的 分享
Hey Stephen my name is Steven (no relation) ...i hav that same issue & i'm gonna try, whats a pick tho?
由完成的 分享
Hi my name is kyle i took the disc stop out and still will not read
由完成的 分享
It Didt Work i have a White Ps3 With a Sliding Cover
由完成的 分享
Hey Stephen my name is Trevor can u do a video on YouTube plzzz
由完成的 分享
显示更多的4条评论
添加一条评论
turn it off, hold in the power button until it beeps once twice and then a 3rd time, take your finger off. then hold it in again you will here it beep once then a short time after a second beep and a short time after that two close beeps take your finger straight off, ur system will turn on it will give u a list starting with restart your system, go for rebuild data base hope this help, u can try them all if this doesnt work
这个答案有帮助吗?
得分 2
3条评论:
Hey Stefan my name is Kenny I don't know if this post is still active or what anyway I have a PlayStation 3 slim it could be the super slim I'm not quite sure I know it's just the one with the sliding door on the top. When I put a disc in it spins but then eventually stop spinning and then starts spinning again and then stops spinning. The eye sensor is lit it seems to be trying to read the disc but whatever the boxes called that slides up and down the metal rods on each side of it one has twist going up the other is just a straight rod so therefore it cannot scan the whole disc I believe it's the problem because that's what I see I have taken it apart and the twist rod on the one side is connected and it does turn but it seems like the maybe the itself stops turning I'm not quite sure but I know it turns and I know it catches it just does not stay turning Maybe everything else I else works hopefully you understand this and if you have any ideas please reply I would gladly appreciate it thank you
由完成的 分享
These way only works for slim ema. Loui
由完成的 分享
I used a CD lens cleaner and I cleaned the inside and my games still don't work....
由完成的 分享
添加一条评论
I have found a cure! On my system everything but the optical drive worked fine, no overheating and good picture. But the optical drive eventually would not read discs! At first I had to put it on its side (opposite side to screw-in vertical stand) and keep it there. That's ONE temporary fix..another that I soon discover when that eventually stopped working was MANUALLY SLIDING OPTICAL DRIVE TO LEFT POSITION BEOFRE STARUP. Found that it was very stiff and the motor wasn't able to move optics to "read" position and where simply stuck in open!
这个答案有帮助吗?
得分 0
1条评论:
Yeah how do u fix it
由完成的 分享
添加一条评论
添加你的答案
mathewyazvac 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 93
总计 128,999
