跳转到主内容
加入维修社区 - 创建账户
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
alternator repair 05 chevy equinox
I have a 05 Chevy equinox.
I took my car to AutoZone for the free alternator and battery test.came up as failed for the alternator.
Any help on repair manual?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
1个答案
已选择的解决方案
bigQ, this may help:GENERATOR REPLACEMENT
Removal Procedure
1. Remove the battery ground (negative) cable from the battery. Refer to Battery Negative Cable
Disconnect/Connect Procedure.
2. Remove the generator B+ terminal nut.
3. Remove the generator B+ lead.
4. Remove the generator electrical connector.
5. Remove the drive belt from the generator. Refer to Drive Belt Replacement in Engine Mechanical - 3.4L.
6. Remove the generator bolts.
7. Remove the generator from the vehicle.
DRIVE BELT REPLACEMENT
Tools Required
J 39914 Serpentine Belt Tensioner Unloader. See Special Tools.
Removal Procedure
1. Remove the air cleaner assembly. Refer to Air Cleaner Assembly Replacement in Engine Controls - 3.4L.
2. Using J 39914 rotate the drive belt tensioner (8) to release the tension on the drive belt. See Special Tools.
3. Remove the drive belt from the right idler pulley (2).
4. Carefully release J 39914 to relieve the drive belt tensioner spring tension. See Special Tools.
5. Remove J 39914 from the drive belt tensioner (8). See Special Tools.
6. Provided the vehicle will not be raised or lifted to perform additional work. Utilizing a floor jack and a wood block, support the front of the engine using the following procedure.
1. Place the wood block between the lift point of the floor jack and the bottom of the engine oil pan.
2. Raise the jack until the wood block comes into contact with the engine oil pan and is capable of supporting the weight of the engine.
7. If the vehicle is to be raised or lifted in order to perform additional work. Support the engine using the engine support fixture. Refer to Engine Support Fixture.
8. Remove the right engine mount. Refer to Engine Mount Replacement - Right.
9. Remove the drive belt from the remaining pulleys.
This is from the service manual. Check this video for better instructions on the belt removal without GM special tools ;-). Hope this helps, good luck
这个答案有帮助吗?
得分 1
2条评论:
Thanks so much, this is exactly what I needed.i have searched everywhere and couldn't find it for free. Thanks.
完成的
bigQ, you are welcome. Best of luck with the task at hand. Let us know if you need any other help and welcome to ifixit.
完成的
添加一条评论
添加你的答案
bigQ 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 69
总计 23,828
