跳转到主内容
加入维修社区 - 创建账户
Inspiron 1545 于 2009 年 1 月 16 日发布,是一款 15.6 英寸的入门级个人笔记本电脑,提供 3 GB 或 4 GB 内存版本。它是 Inspiron 1525 的继任机型。
Why is computer getting really warm?
After I have been using my laptop for a while the computer starts to get very warm and is to hot to use on my lap. I have turned down the power usage settings on things like the screen and processor but this still happens.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
The most likely reason for this is that your laptop is not receiving proper ventilation while in use. Using your laptop for long periods of time without a cooling pad or external fan will normally cause it to overheat. There may be other less obvious problems that your laptop is experiencing, which can be found in the following link: Dell Inspiron 1545 Troubleshooting
这个答案有帮助吗?
得分 0
添加一条评论
Dell Inspirons have terrible placement of their cooling fans, IMO. (I have one too, which I inherited when its fan overheated and broke and was too expensive to repair...I repaired and upgraded, then inherited it...)
The fan is at the bottom, blowing air down (?!?). So if it's sitting on top of your lap (i.e. like a laptop...) often the fan is almost completely blocked by its contact with your lap.
It's a bad design. I'm quite surprised at how long it has remained that way. The only real solution that I know of is to prevent a snug fit between your lap, or any surface, especially soft one) and the underside of the computer. Prop it up on something so there is airflow to the fan vents onthe bottom.
Otherwise, as you've observed, it gets extremely hot. The next step is for the fan's motor to burn out. This is one of the most common failures for the Inspiron; it requires replacement of the fan. It's a cheap part, but repair involves taking almost everything out of the case to get at the fan. (An aside: this repair does take considerable time and patience, but it's an excellent one to do if you're interested in repair but not terribly experienced. It's not really that hard, just tedious, and the ifixit guide is excellent. And it's a great opportunity to upgrade just about anything in your laptop, since you'll be taking it out anyway. And you'll learn a lot.)
BUT. Prevention is much better. Anything that allows that air flow will do it. If the bottom of the laptop stays fairly cool, you're succeeding. A quick search at your favorite retailer for "cooling laptop stand" will reveal plenty of retail options. Or improvise something. Just be sure there's a grill or cutout or prop beneath that part of your laptop's underside--the part with the vent holes that gets too hot to touch if it sits on your lap. A small investment now will save you a major repair later.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kyle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 964
