跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
OEM or generic glass digitizer Replacement?
Some claim to be "OEM" original equipment manufacturer in this case that would be Foxconn, I've contacted two Premium Service eBay sellers with very high reputation, one claims to be (100% OEM made by Foxconn) the other says that only Apple could get their supplies from Foxcoon.
If it is possible to get hold of the genuine article or is this another marketing term if not is there a way to tell a fake from OEM?
Have e-mailed Foxconn directly with query will post reply.
There does appear to be some consistency in pricing on all "OEM/original" digitizers of over £40/$67.41
Thanks once again for your time :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
5个答案
已选择的解决方案
Comparison:
1. The QR code. The one on fake digitizer is a little big and scattered. You can see the picture one. Black one is original and the white one is custom.
2. If there is a visible but can't feel ring around the front camera hole like picture two, it must be original one. And the fake one doesn't have. That's the most important evidence.
3. If you found there is the glue traces around the edge of the digitizer cable, it's likely the custom one. because the original one is manufactured carefully with original adhesive but the fake one is glued together. You can see the picture three.
4. You can tap the digitizer. Tap the fake one sounds like tap a single glass, but tap the original one sounds like tap a glass on a book or something thick. This comparison can't be used alone but can with comparison 2.
5. That also should be used with above comparison. Drop a drop of water on the surface of glass then move the digitizer, the drop on the original digitizer can move quickly but the one on custom digitizer will move slowly just like nearly stick on the glass.
6. The weights are different. The original one is heavier than custom one. For example, the original digitizer for iPad 2 is about 121.5g while the custom one is about 106.4g.
Hope can provide you some info.
这个答案有帮助吗?
得分 3
2条评论:
Sophia (σοφία, Greek for "wisdom") a Wikipedia copy & paste
You must get this all the time from the geeks like me, but I think I'm in love ;)
Kidding aside, simply an awesome in-depth reply with photos,
All I get from Google search results these days are paid/sponsored-search-results/ads.
Your help is greatly appreciated AAA*****
完成的
Neither of those are OEM the digitizer is outline is a "goldish" color on OEM digitizers
完成的
添加一条评论
Hello guys, please tell me ebay guy contacts which can to sell me original ipad air digitalser.
My email: magvajus3@gmail.com
Thanks
这个答案有帮助吗?
得分 0
添加一条评论
hey send me an email on a place to get oem parts. thanks. email is itronic2004@yahoo.com
这个答案有帮助吗?
得分 0
添加一条评论
Send for me too
Controsol@gmail.com
这个答案有帮助吗?
得分 0
1条评论:
Me as well braschuk@hotmail.com
完成的
添加一条评论
me three: real.oem.ipad3.digitizer@mailinator.com
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aled 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 13,213
