跳转到主内容
加入维修社区 - 创建账户
The LX260 Rumor is a simple slide phone with a 1.3MP camera, MP3 player and a microSD slot.
Phone won't charge unless charger is plugged in at a certain angle.
My LG Rumor isn't charging and I believe the connectors are to blame. My wife has same phone that charges fine with the same charger. I did notice that when I plug the charger in to my phone and put something heavy on it, the phone will charge.
Is there a way to replace the port where the charger plugs in? How hard would it be to do this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 22
16条评论
Woah dude! That was a waste of money! I had the same problem on my phone and I found that rich Dave was wrong. It was pocket lint. If you already replaced the phone, you could have just removed the lint yourself for free. That's what I did.
完成的
I just did what Drake said and it instantly fixed the issue. Thanks!
完成的
How do u he the lint out
完成的
Too funny but I just had the same problem. It was clear of lint so that wasn't the problem so I used a letter opener to pull back the prongs in the ear piece and it works now without any help holding the charger connection in place. I believe it was due to the way I was pulling it out of the charger. I'll more carful from now on.
I hope this help someone :-)
完成的
Mine still won't work I pull it in certain places I know it works but know those places aren't working
完成的
显示更多的11条评论
添加一条评论
7个答案
已选择的解决方案
Sounds like either the cable/connector on the charger is faulty or the connector/socket on the phone is damaged
Try a different charger and see if it works OK.
Replacing the connector on the phone while possible is likely, you'd probably need to pull the main board out to do this. Getting a suitable replacement may not be easy either!
这个答案有帮助吗?
得分 6
12条评论:
Thanks for the reply. The charger works fine on my wife's phone, so it is the socket on my phone. I guess I'll probably just replace the whole phone.
完成的
Removing the pocket lint is a far better approach! Use a pin!
完成的
I just cleaned the charger contacts on my iPhone. I was amazed at how much lint was packed in that small opening. Do not get rid of your iPhone. I also noticed how much dust/lint was on the charging cord itself and you're constantly pushing that into your iPhone. Thanks for the tip!
完成的
This totally worked !! I had to bend the charger a certain way for it to charge but it wouldn't stay charged. Very frustrating! I used a pin and gently scraped the inside of the port .... oh my word, the lint came out in chunks !!! After a couple of gentle scrapes .... magic !! My phone is charging without any problems !! Thanks so much for the tip. I was about to buy a new phone. !
完成的
i need help i have a asus zenfone and i have to move my charger a certain way what should i do
完成的
显示更多的7条评论
添加一条评论
最有帮助的答案
it's pocket lint! same thing happened to my iphone 5, got worse and worse until i had to torque the charger at such an angle and with such force that it would only charge if i put 3 dictionaries on top of my phone to hold the cable tension.
went into an apple store and they cleaned out pocket lint from the charger jack. charges perfectly now.
they warned me not to try to remove the lint myself - they use a special pick that is gentle on the internal charging components i guess. but this was a super simple fix!! try it out!
这个答案有帮助吗?
得分 10
18条评论:
OMG I could kiss the $@$* out of you right now ! I have the same problem with my phone and I used a safety pin to remove the lint and my phone is fixed now! :D thank you so much
完成的
amazing! used a thin sewing needle, and it worked like a charm. Thank you thank you!!!
完成的
Fantastic! I removed !&&* lot of lint from charging jack. It works like charm now. I was considering loosing a good amount of money on that by Apple service center. But thanks to awesomeness.
完成的
WOAH- who woulda thunk that there was lint up in there?! Thank you so much!
完成的
Wow... I can't believe that worked. Also, for others, sometimes it really takes some digging. Took a while but I got all the lint out. Thank you so much!
完成的
显示更多的13条评论
添加一条评论
Whoa, somebody dug this old question up. Richdave's answer is pretty much spot on. The DC port is soldered onto the logic board. Replacements are available at places like this.. Take a look at this teardown for more information on how to get to the part.
这个答案有帮助吗?
得分 4
添加一条评论
I had this exact problem with my iPhone 6. I actually found that a small amount of pressured canned air (in my case for example, Memorex Air Duster) cleaned out the lint no problem and my phone charges fine now, regardless of angle.
这个答案有帮助吗?
得分 1
1条评论:
Air has never worked for me and I have tried dozens of times. Its a working phone not an office desk job phone so it gets real dust no matter what I do to prevent. You would think they would make a better design but I guess they get off having to have you bring it in every month or two.
完成的
添加一条评论
Just wanted to come on here and say thank you to everyone that posted about lint being the problem. I have lived with my phone only charging with the charger pulled to one angle for over a year. I dug out the charging port with the end of a small paperclip and viola, charges at all angles every time. THANK YOU THANK YOU THANK YOU!
这个答案有帮助吗?
得分 1
2条评论:
YES! Repair shop said my 6S+ would cost $109 to fix (by replacing the charging port). I found a safety pin in my dresser, turned the phone off, and carefully expelled the lint from the port for free.
It was so compacted that compressed air didn't get anything out, so make sure you shine a light in there to get a better view. You should be able to tell just by the feel. If it's spongy when you stick the pin in, well, Friendo, you've got The Lint.
完成的
I can't see anything. Too small. Maybe with a magnifying glass?
完成的
添加一条评论
Thank you! Totally lint or at least dust in my Galaxy S7. I was about to buy a new cable. A pin didn't work, but blowing on the port and the charging cable plug cured the problem!
这个答案有帮助吗?
得分 0
添加一条评论
Im using an ipad mini, iv burnt through 6 wires and i still dont know, i use a normal ipad charger, the wires charge perfectly on my phone and the beginning on my ipad, after a while the wire stops working. I tried the lint thing, nothing and idk what to do
这个答案有帮助吗?
得分 0
1条评论:
Amazon's got them on sale
完成的
添加一条评论
添加你的答案
pipfisher 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 31
过去 30 天: 193
总计 382,288
