跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的LG Rumor (LX260),请使用我们的维修手册
  1. LG Rumor LX260 Teardown, LG Rumor LX260 Teardown: 步骤 1 中的图像 1,3 LG Rumor LX260 Teardown, LG Rumor LX260 Teardown: 步骤 1 中的图像 2,3 LG Rumor LX260 Teardown, LG Rumor LX260 Teardown: 步骤 1 中的图像 3,3
  2. LG Rumor LX260 Teardown: 步骤 2 中的图像 1,2 LG Rumor LX260 Teardown: 步骤 2 中的图像 2,2
    • Now, start by removing the battery, it is attatched to the back cover, and can be removed by pushing the tab back.
  3. LG Rumor LX260 Teardown: 步骤 3 中的图像 1,2 LG Rumor LX260 Teardown: 步骤 3 中的图像 2,2
    • Remove these 6 phillips screws:
    • These two top screws are covered by rubber plugs that can be removed by a small flathead screwdrivew, or a fingernail.
  4. LG Rumor LX260 Teardown: 步骤 4 中的图像 1,2 LG Rumor LX260 Teardown: 步骤 4 中的图像 2,2
    • Remove the covers for the Headphone, Micro SD and Charging connectors, but be careful, they are still connected, pull them only as far as they will come out!
  5. LG Rumor LX260 Teardown: 步骤 5 中的图像 1,1
    • You should now be able to lift the back cover off, it is held on with a mild adhesive, so a little force may be required the first time.
  6. LG Rumor LX260 Teardown: 步骤 6 中的图像 1,2 LG Rumor LX260 Teardown: 步骤 6 中的图像 2,2
    • Remove the "Camera" and "Volume" buttons.
    • Be careful, the actual buttons, ane attatched to the locic board with a very thin ribbon cable, only remove the button covers.
  7. LG Rumor LX260 Teardown: 步骤 7 中的图像 1,2 LG Rumor LX260 Teardown: 步骤 7 中的图像 2,2
    • Remove these two phillips screws:
    • Now, removed the highlighted clips (2nd Picture) this will free the logic board.
    • I recomend starting with this one, and once this tab is free, you can just slide it around the other clips.
  8. LG Rumor LX260 Teardown: 步骤 8 中的图像 1,2 LG Rumor LX260 Teardown: 步骤 8 中的图像 2,2
    • Now, pivot the logic board up, to reveal the LCD/Numeric Keypad Cable, remove this with a spudger or flathead screwdriver.
    • You should now be able to remove the logic board.
  9. LG Rumor LX260 Teardown: 步骤 9 中的图像 1,1
    • The Logic board:
    • The CPU is a Qualcomm MSM6100 ARM Processor
    • The RAM, it is manufactured by Hynix
    • The Camera 1.3MP, not bad
    • The SD Card Slot:
    • Speaker [Speakerphone]
    • Headphone Jack:
    • Battery Contacts:
  10. LG Rumor LX260 Teardown: 步骤 10 中的图像 1,3 LG Rumor LX260 Teardown: 步骤 10 中的图像 2,3 LG Rumor LX260 Teardown: 步骤 10 中的图像 3,3
    • The keypad cover is easily replacable, and simply lifts out.
  11. LG Rumor LX260 Teardown: 步骤 11 中的图像 1,3 LG Rumor LX260 Teardown: 步骤 11 中的图像 2,3 LG Rumor LX260 Teardown: 步骤 11 中的图像 3,3
    • Seperating the phone sliding assembly:
    • Remove these 4 Phillips screws:
    • Now, lift it off, threading the Screen/Number Pad Cable Through the hole.
  12. LG Rumor LX260 Teardown: 步骤 12 中的图像 1,3 LG Rumor LX260 Teardown: 步骤 12 中的图像 2,3 LG Rumor LX260 Teardown: 步骤 12 中的图像 3,3
    • Remove these phillips screws:
    • To remove all 6, you will need to slide the sliding assembly to get to the center two screws.
    • Now, using a spudger, or flathead screwdriver, seperate the two halves of the assembly, threading the data cable through it's hole.
    • This may take a little force since a mild adhesive is applied around the rim.
  13. LG Rumor LX260 Teardown: 步骤 13 中的图像 1,2 LG Rumor LX260 Teardown: 步骤 13 中的图像 2,2
    • Now, detatch the data cable from the board using a spudger, be careful, it is a fragile connector, and you should lift it straight up.
    • Now, remove this piece of clear yellow-tinted tape covering the connectors.
  14. LG Rumor LX260 Teardown: 步骤 14 中的图像 1,2 LG Rumor LX260 Teardown: 步骤 14 中的图像 2,2
    • You will now need to remove this piece of gold-mesh tape.
    • BE CAREFUL WHEN REMOVING THIS, SINCE IT PROVIDES A GROUND, AND WILL NEED TO BE PUT BACK IN UPON RE-ASSEMBLY!
  15. LG Rumor LX260 Teardown: 步骤 15 中的图像 1,3 LG Rumor LX260 Teardown: 步骤 15 中的图像 2,3 LG Rumor LX260 Teardown: 步骤 15 中的图像 3,3
    • Now, flip this tab up, towards the bottom of the phone, and remove the speaker/side-button cable.
    • Now, slowly lift the cable up, minding the adhesive on the back.
    • When you come to the buttons, be especially careful, and when you get to the speaker, use a flathead screwdriver, and pop the speaker out.
  16. LG Rumor LX260 Teardown: 步骤 16 中的图像 1,3 LG Rumor LX260 Teardown: 步骤 16 中的图像 2,3 LG Rumor LX260 Teardown: 步骤 16 中的图像 3,3
    • Using a spudger or flathead screwdriver, lift this tab up, to release the display cable.
    • Now, guide the cable out of the connector, until you can set it on top of the assembly.
  17. LG Rumor LX260 Teardown: 步骤 17 中的图像 1,3 LG Rumor LX260 Teardown: 步骤 17 中的图像 2,3 LG Rumor LX260 Teardown: 步骤 17 中的图像 3,3
    • Now, to remove the board, use a flathead screwdriver or spudger to clear the tab on one side, then remove the board completly, similarly to the logic board.
  18. LG Rumor LX260 Teardown: 步骤 18 中的图像 1,2 LG Rumor LX260 Teardown: 步骤 18 中的图像 2,2
    • You can now lift the keypad cover off, just like we did earlier with the alphabetical keyboard.
  19. LG Rumor LX260 Teardown: 步骤 19 中的图像 1,2 LG Rumor LX260 Teardown: 步骤 19 中的图像 2,2
    • Unfortionatly, the LCD panel is held in place by a heavy adhesive, and removal will almost certianly crack the screen, so only remove it if you are replacing the screen.
  20. LG Rumor LX260 Teardown: 步骤 20 中的图像 1,1
    • Group Shot!
Chris Green
于10/11/09注册
36,978 声望
创作了49篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,528篇指南
2条评论
I'd recommend not opening the screen bit in any way shap or form.
qwerty keyboard - 回复
I tore down an AX260. Tear down is identical. I removed the screen, too. I heated the entire glass with a variable heat gun set to approximately 140F. I monitored the temperature of the glass with a non contact infrared thermometer. At just under 140F the screen separated from the glass on three sides. I hinged the screen and applied the heat to the remaining adhesive. As it warmed the adhesive disengaged from the screen intact. The adhesive acts like a sticky foam. Screen was clean with no adhesive residue and would be easy replace glass or screen at that point.
Thank you for a very nice tear down guide.
jharden2 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 51,925
