跳转到主内容
Nokia Lumia 920由诺基亚开发并于2012年11月发布,搭载Windows Phone 8操作系统。
56 个问题 查看全部
Do I need to replace the LCD or the digitizer?
I woke up this morning, unlocked my phone, and the left side of the screen had colourful vertical lines running from the top to the bottom.
The phone is still working perfectly well, the touchscreen is working, there are no cracks in the glass, everything is fine apart from the visual mess.
Do I need to replace my digitizer? My LCD? Is both broken? Or is a connection loose. I've dropped my phone several times before this happened.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
已选择的解决方案
Max, looks like you need a new LCD. I previously tried to separate the digitizer from the LCD with the right tools and still failed. I would suggest you replace the assembly. Here is a a good video that shows hot to separate the parts if that is the way you want to go. I prefer to replace the complete assembly since it does have a higher rate of success. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for the advice! I think I'll still go with the parts, buying the complete assembly (digitizer+glass+LCD) is quite a bit more pricer :/
完成的
Max, sounds good. Create a guide while you work on your Lumia and post it. I am sure it will help lots of people after. Best of luck to you.
完成的
添加一条评论
最有帮助的答案
I'm not sure what phone that is or weather you can seperate digatizer from the lcd.. But it looks like lcd damage look up the guide for the phone and see if it can be seperated if it can then it's a lcd you need..
Also I would check that the connectors inside haven't come loose and are seeded correctly
这个答案有帮助吗?
得分 2
1条评论:
It's a Lumia 920, and yes you can split the two up! There shouldn't be anything wrong with the digitizer yeah?
完成的
添加一条评论
Max, I just replaced the whole assembly on this phone a couple weeks ago. Yes, the whole assembly is more expensive, but trying to remove the glass without breaking or at the very least cracking the glass, may prove difficult and time consuming. Heck the whole assembly only cost $79. Then you've got to have the right adhesive to put the glass on the LCD. Now you have adhesive left over, that you hopefully will never need again. The glass, digitizer and LCD are factory-made as one piece. Without the right equipment to separate the two, could cost you more in the long run.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Max 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 1,695
