跳转到主内容
加入维修社区 - 创建账户
型号 A1046 或 A1095 / 1280x854 屏幕分辨率
Hard drive cable plug in
Hi,
I guess I screwed up putting in a new 120GB hard drive. The computer doesn't see any hard drive. I was more concerned about removing the cable from the hard drive without bending any pins and I think I plugged it in wrong. There are 2 rows of pins on the left side of the pins and then a space and I am not sure if I start the cable there or skip those 2 rows and plug it in? Thanks.
Thanks...I went to the other side...Will switch it tomorrow when I am more focused and not bummed
I opened it up again and everything was connected correctly. Did this a few more times since it still would not see the HD. The last time as it started the install and no HD to put it on I went to the Utility program and it saw the HD. I erased it and started the install. It is going along well.
Thanks to all for the help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Hi! I pasted in a link below to a picture of the pins on a hard drive. Looking at the picture, you want the plug to cover the big chunk of 2 rows of pins on the right side. If that means the 4 pins to the left that are separated by a space are not connected to the plug, that is fine -- some plugs cover the additional pins, and some don't.
http://www.datarecoverytutorial.com/wp-i...
这个答案有帮助吗?
得分 1
1条评论:
Also notice the missing pin. You should have a blank spot on the connector that fits that spot. Ralph
完成的
添加一条评论
添加你的答案
andersong 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 17
总计 1,997
