跳转到主内容
加入维修社区 - 创建账户
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
Why isn't my battery charging?
I put my charger in my Samsung Galaxy Tab 2 tablet to charge it up last night and it keeps saying it isn't charging. It has the charging icon but has a red cross even if i take the charger out. What do I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 19
2条评论
What kind of charger are you using?
完成的
dont use charger below than Tab 2
完成的
添加一条评论
4个答案
最有帮助的答案
Emily Denton, I'd suggest that you plug the charger in, then hold volume up and down buttons down at same time for about 10 seconds and release after. Your boot up screen should come on and your battery should be low. Turn your device off and let it charge normally. Hope this helps, good luck.
这个答案有帮助吗?
得分 3
5条评论:
This worked on mine screen went black but loaded like a reboot and my battery is now charging
完成的
Wow! Thank you so much for the tip <3
完成的
new battery from service center for Galaxy Tab 3 but charging problem is even worse. what in the world?
完成的
Worked for mine! Awesome! Thank you! :)
完成的
Will this method get rid of all my apps and files?
完成的
添加一条评论
I opened the tablet up, disconnected the battery wire (just used a small blunt object underneath and popped it up), took the battery out and waited a minute. Put the battery back in, connected the wire back on, put the backing back on the tablet and plugged it in. It worked. There are tutorials on youtube on how to replace the battery. Although I was not replacing the battery, simply just re setting it, that's how I got mine to start charging again. Good luck.
这个答案有帮助吗?
得分 1
添加一条评论
My tablet is charged when I take out cable the charging goes low tal me what I do
这个答案有帮助吗?
得分 0
添加一条评论
You should try changing outlets. If it doesn't work...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Emily Denton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 41,220
