跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
REPLACE BATTERY NOW condition
hi,
I was using my macbook without the AC cable, running by its battery which has no any draining issue before. After I got 4% battery, I connected the cable but it says REPLACE BATTERY NOW. as I said, the battery was perfect with its performance before this and I haven't any trouble before. When I disconnect the AC cable, it goes off.
My macbook like a new and I don't use it much because I have iMac.
What should I do please!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Did they end up replacing your battery at no expense to you? I would imagine they did. Please post a follow up. Thanks!
完成的
添加一条评论
1个答案
已选择的解决方案
I could see an older model needing a new batt but a early '13 model shouldn't need it for at least 3 yrs.
Given the age of your system I would recommend going to Apple to have it repaired under Warranty ASAP as your time is running out (1 year without an extended Apple Care warranty).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
abdullah 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 478
