Door contact? preventing microwave from running?
JVM1340BW002
I believe the switch or relay that tells the microwave the door is closed is preventing it from running. If I hold the door in a specific position it will run. Can this switch be changed easily? What is the part number?
Thanks,
Scott
4条评论
Microwave runs but doesn't always heat? Is it the door?
由 l.b.lewis 完成的
My over the range microwave shows error “door” and does not turn on. But after repeated pushing the button it does. Any help.
由 Arijeet Sengupta 完成的
I have this issue also. Mine will also turn on the light and start running with no time on the clock! I will never buy another LG. I had a Panasonic for 18 years (i got it as a wedding gift!), then bought the LG and have had it only 2 years.
由 Phil 完成的
Knowing others have the same issue, item should have been recalled or customers should have received a replacement part. Over time, technology should get better, not worse. So my old unit lasting 18 years shows true quality and workmanship.
由 Phil 完成的
