跳转到主内容
The Samsung Intensity II has a full QWERTY keyboard, messaging and e-mail tools, and search and navigation extras.
13 个问题 查看全部
问题已关闭
Ribbon cable broken on Samsung Intensity II
My ribbon cable is broken (torn) on my Samsung Intensity II. I know this because when I slide the phone open there is a sheared ribbon cable sticking out. Do you have step by step instructions on how to replace this cable?
Thanks a bunch.
Nick
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Nick, unless you take it apart, you will not know for sure which ribbon cable it is. Use this teardown to get to your logic board. Let us know what you found. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
2条评论:
Thanks. I used your teardown slides and the following youtube video (http://www.youtube.com/watch?v=75jreo87O...) to successfully take apart and replace the "L" shaped ribbon cable. The only tricky part in my opinion was folding the new ribbon over the keyboard skeleton. Again, thanks for your help! Nick
完成的
Do you know what this cable is called? I need to replace the equivalent on an intensity 3 but I dont know where to look for one
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 1,059
