跳转到主内容
沃克斯豪尔汽车的修理和支持指南。 成立于1903年的英国汽车品牌。
59 个问题 查看全部
change indicator relay on Vauxhall Combo
My right hand indicators don't work properly and I have been told that it is probably the relay. And wouldn't you know it, apparently it's a real pain to replace? Because of its location. Apparently it is behind the battery and something else. Any help please.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
6条评论
What year is your Vauxhall?
完成的
It's a 2005 55 plate
完成的
Does that relay also control the reversing light?
完成的
any more my light do not work 1.9 vauxhall combo reg 04
完成的
I have no flasher and hazards . Fuse and relay is ok on vauxhall vivaro 2004
完成的
显示更多的1条评论
添加一条评论
1个答案
最有帮助的答案
Geoff Heyes, the relay is located under the hood, adjacent to the battery. You should see a black weather sealed box. You will need a long extension and a Torx ( I read a T20) socket to remove the cover. The indicator relay is the large yellow one.
information from here
这个答案有帮助吗?
得分 2
3条评论:
That's a great help.
Many thanks.
Geoff
完成的
You are welcome, best of luck to you.
完成的
This was really helpful to me many thanks
完成的
添加一条评论
添加你的答案
Geoff Heyes 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 36
过去 30 天: 135
总计 31,623
