跳转到主内容
沃克斯豪尔汽车的修理和支持指南。 成立于1903年的英国汽车品牌。
change indicator relay on Vauxhall Combo
My right hand indicators don't work properly and I have been told that it is probably the relay. And wouldn't you know it, apparently it's a real pain to replace? Because of its location. Apparently it is behind the battery and something else. Any help please.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
6条评论
What year is your Vauxhall?
完成的
It's a 2005 55 plate
完成的
Does that relay also control the reversing light?
完成的
any more my light do not work 1.9 vauxhall combo reg 04
完成的
I have no flasher and hazards . Fuse and relay is ok on vauxhall vivaro 2004
完成的
显示更多的1条评论
添加一条评论
2个答案
最有帮助的答案
Geoff Heyes, the relay is located under the hood, adjacent to the battery. You should see a black weather sealed box. You will need a long extension and a Torx ( I read a T20) socket to remove the cover. The indicator relay is the large yellow one.
information from here
这个答案有帮助吗?
得分 2
6条评论:
That's a great help.
Many thanks.
Geoff
完成的
You are welcome, best of luck to you.
完成的
This was really helpful to me many thanks
完成的
Hello,
Thank you, this is super helpful, even now!
If you're able, do you have a replacement source for the info? I have the same issue with my indicators, and want to figure out what relay to buy...plus my wipers won't go max speed anymore, which I think is linked to one of these also in the rear fusebox. The manual I have doesn't explain any of them, sadly.
Many thanks in advance!
完成的
@larn what exact year, model etc. is your Vauxhall? Let's see what we can dig up :-)
完成的
显示更多的1条评论
添加一条评论
This relay is located near the BCM module. It is located under the plastic that covers wiper linkage and motor. There is another plastic that covers BCM module and relays near it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Geoff Heyes 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 20
过去 30 天: 76
总计 33,799
