跳转到主内容
The Motorola Droid 4 is a smartphone made by Motorola that was released with Android 2.3 and is upgradeable to Android 4.1.
How do we Replace either the Micro-USB OR micro-HDMI jack?
Before commenting, please know: I KNOW where to order the jack parts, I just need to know HOW to replace them.
2nd and sometimes even 1st of the major two problems of the D4 was not just the battery, but relatted, the micro-usb port failure.
Although there is an excellant micro-usb cleaning video on YouTube (and that does work in most cases), what is clearly lacking but needed should be within the teardown, we need to see how to replace the micro-usb and micro-hdmi jack ports. We don't even see pictures of their freedom! Frankly only mentioned as to their existence. Please add to and change the teardown to explain this procedure (should be part of the teardown, shouldnt need to be a separate video)
Also , where can we get the exact same OEM jacks -I see alot of Razor links, but nothing for D4 yet.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
pretty much impossible, they are micro soldiered to the main board. I have tried doing the same thing on a htc evo 4g and even the nano fabrication lab at my technical school could not perform the repair.
这个答案有帮助吗?
得分 0
2条评论:
So, then, I would need to just order that board (35.00 OEM on Amazon)?
完成的
if you are talking about the main board yes!
完成的
添加一条评论
添加你的答案
Dan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 366
