跳转到主内容
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
ipad wont slide off after I replaced the wi fi cable
i recently replaced my ipad 2 screen and accidental messed up the wifi cable,i have placed an order for a new one however i also have an issue with it not sliding on it starts up ok it just wont let me slide to unlock it ,could that be caused by the wifi? when i plug it into my laptop it says i must enter the passcode on the ipad i never set it up using the passcode.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
You have either a defective screen, or you have mis-installed your screen. Check to see if the black plastic connector is latched on both sides of the digitizer flex.
Not related to WiFi.
If you have iOS 7--the setup wizard prompts you for a passcode at set up. You may have typed one in just to get past that screen.
这个答案有帮助吗?
得分 0
3条评论:
thank you i just ordered another replacement screen from a different company this one has the power button and stickers already on it im praying this works thank you again for your help . i cant turn it off without the slide button and was wondering its on and i know not to touch the lcd with my fingers if it was the screen would the lcd work? is there a way to test if its the screen?
完成的
If you can see the image, the LCD works.
完成的
thank you so very much for your help it is fixed the replacement one i received didn't work,the second one worked great.
完成的
添加一条评论
添加你的答案
lisa0201 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 115
