跳转到主内容
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 个问题 查看全部
backlight comes on, but goes off after a while.
Did you ever sort this out?
I have a White MacBook with the same problem. backlight comes on, but goes off after a while. It is not a mechanical problem. Moving the lid makes no difference and wiggling the cable on the inside makes no difference. Interestingly turning the machine off and back on restores the backlight (for a while).
Originally one wire in the inverter cable was broken (it got caught in the hinge). I fixed the wire but now I have this issue. Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
How did you fix the wire? What are the last three digits of your computer?
完成的
添加一条评论
1个答案
已选择的解决方案
Sounds to me like your inverter is failing or the inverter wires are failing when heated. To test it hook it up to an external monitor and see if the monitor goes off when the screen does. If both fail at the same time it would be a GPU failure. It the monitor remains on, you will have isolated the issue to the inverter or inverter cables.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
harald 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 5
总计 112
