跳转到主内容
Repair guides for cell phones by manufacturer Nokia, including smartphones and a wide variety of the iconic "brick phones". This category is for phones not using an Android or Windows operating system.
508 个问题 查看全部
Why is the digitizer on my Nokia Lumia 620 not working?
Hey guys,
After changing the screen/digitizer on a Nokia Lumia 620 it was working fine, a few weeks later it suddenly stopped working. The flex cable and screen looked completely fine, so I have no clue what's wrong. I even tried getting a new screen and it didn't work either. Anyone experienced this before or has any clue on what the problem could be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
Have you tried a reset to see if it works?
完成的
I'm having the same problem with a digitizer I got from repairsuniverse.com, Omran did you ever fix this problem? And Aristeidis, I looked up how to downgrade here http://forums.wpcentral.com/nokia-lumia-... but the software for rm-820 is not available in navifirm+ Any other ideas
完成的
I have my lumia 638 digitizer replaced, But now the touch is not working.
完成的
添加一条评论
5个答案
已选择的解决方案
Omran, if a hardware reset does not work, and you can not access the reset menu due to a non-functioning touch screen, I suggest to start with a Software/ OS reset. The hardware key combination can be used instead of the digitizer. This may cause some data loss.
Step 1
Make sure the phone is turned off.
1. Press and hold the power key
2. Phone vibrates (release the power key)
3. Press and hold the volume down key
4. Exclamation mark is shown on the screen (release the volume down key)
Step 2
Input the following key combination:
1. Volume up
2. Volume down
3. Power
4. Volume down
Step 3
The phone will reset and boot up automatically. This may take a few minutes.
Should this not accomplish anything, and you already tried a new digitizer, you may have a faulty touch screen IC. Attached is an image of the trouble shooting guide for the digitizer. Hope this helps, good luck.
这个答案有帮助吗?
得分 4
1条评论:
This work for me hold the down key and power key wait for it to reset when you see nokia come up release power key and keep pressing down key don't stop you will feel it vibrate keep pressing it don't let go until you see you look screen then you touch will start to work again. it look like a software problem. This were done on my nokia lumia 928
完成的
添加一条评论
it's just the new amber update of nokia, anything else but original digitizer doesn't work. i suggest you to downgrade your firmware.
这个答案有帮助吗?
得分 1
添加一条评论
Today i crack my nokia 520 dizier and i replace new dizider and thats not work what i do? :S
这个答案有帮助吗?
得分 0
添加一条评论
Me too.
I already tried almos all versions of software released and not one of them works 100%
Some works fine but after reboot not any more...
这个答案有帮助吗?
得分 0
添加一条评论
I changed a digitizer on my lumia 920 ..and now the screen is showing upsided down...and my digitizer is not working...what to do...??
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Omran 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 15,113
