跳转到主内容
戴尔所制造的笔记本电脑。
3028 个问题 查看全部
Battery temporaily disabled error
When powering computer up we get "Your battery is temporarily disabled. Please turn off your computer & try again when the unit is back to operational tempature.
We can do F1 and still power up. Error message is new.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 12
添加一条评论
4个答案
已选择的解决方案
Alvin Gerholdt, try this " The battery failing is the most likely culprit but you should check to see if there are any problems with either the notebook or Ac adapter before rushing out and replacing the battery.
I would start by checking the bios, start the system tapping F2 to enter the bios, you can also tap F12 and choose bios from the menu. Once in the bios look for the option for AC adapter warnings, if they are disabled enable them and save changes. If there is a problem with the adapter you should start getting errors about the adapter.
If the Adapter seems alright, disconnect the battery from the system and power down the notebook. Wait an hour or so and then replace the battery and restart the system and see if you continue to get the message. If you can run the notebook on battery only allow the battery to fully discharge and then charge it again and see if the problem returns." from here. First instinct is, bad battery. Hope this helps, good luck.
这个答案有帮助吗?
得分 4
1条评论:
2020 note: As someone who is used to working on more Dell equipment then Lenovo because it's so common here it's easier to get parts for them/parts systems for major repairs like if I need a battery and cannot wait, temp failures are a early warning towards a permanent failure. I don't know how many times it needs to happen, but knowing how paranoid Dell is it's probably low before they throw the permanent failure flag. I've already tripped it once so far.
I wouldn't trust a pack that starts having this problem, or I'd keep a spare with that laptop. It usually begins to be an issue once the packs wain in capacity - my E6440's 29-32% health pack did it. Consider it an early warning it's almost at the end of it's life; not a potential connection fault. On others like some of the flat cell Dell batteries, it's a possible flag for future expansion problems where you need to buy a new battery.
完成的
添加一条评论
这个答案有帮助吗?
得分 1
添加一条评论
This was happening on my Dell P57G laptop with 11.1v battery. I checked several things and saw that the power supply was producing voltage. The computer when powered on would show the battery disabled and the adapter message was showing a problem as well. Something like not recognized and adjusting for the power needed to run laptop. I then noticed the plug was not inserting properly. Upon closer inspection, the center pin was bent to the side. The laptop would run like this when plugged in, but would not charger the battery. I unplugged and let the power run out of the power supply completely and then used a tiny Philips head screwdriver to bend the center pin back into position. The Philips head allowed me to have a groove to sort of grab the pin and push it gently without slipping off. Sure enough, plugged the power cord back into laptop. It seated like new and the battery charging light came on. Booted up and no more messages about battery being temporarily disabled or the adapter not being recognized.
这个答案有帮助吗?
得分 1
添加一条评论
Dell 7548 bought a new battery and same thing worked fine for a while and then now Everytime it shows the disabled charging. Going to try unplugging and draining battery all the way otherwise will have to fork up for a new battery
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alvin Gerholdt 将永远感激不已
浏览统计数据:
过去 24 小时: 12
过去 7 天: 66
过去 30 天: 286
总计 46,547
