跳转到主内容
加入维修社区 - 创建账户
硬盘或机械硬盘的维修信息。硬盘是磁性数据存储设备。由于其成本低廉且数据密度高,它们被广泛应用于大多数台式机、笔记本电脑和服务器中。
Compatibility in swapping out the PCB...
Hi all -
So I'm wondering if anyone has any knowledge about swapping out the PCB (printed circuit board) on 1.8" HDD....
I have this Samsung model (Samsung HS16VJX - 1.8" HDD 160GB) where the OEM PCB is a direct to USB port. I need a ZIF drive (yes, for an iPod) and found someone with a PCB for a Samsung HS081HA 80GB 1.8" ZIF Hard Drive. Thought about purchasing it and hoping for the best, but would prefer to have some confidence behind spending the money.
Let me know. Much appreciated!
Jason
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Yeah... that much I knew. I just thought perhaps since they were both 1.8 Samsungs, I had a much better chance of it working. Just wondering if anyone else has had success. Thanks Cris
Jason
由完成的 分享
添加一条评论
3个答案
已选择的解决方案
Hi,
you can try it.
But every drive has a memory chip on the PCB that stores unique informations about this certain hard drive. If you buy a PCB from another drive the stored informations may not fit to your drive.
这个答案有帮助吗?
得分 3
1条评论:
agreed +
由完成的 分享
添加一条评论
I have successfully received the PCB,I replaced the BIOS chip on the PCB by the original and it has worked perfectly.I was able to retrieve complete information from the hard disk. Wish this can help.
这个答案有帮助吗?
得分 1
添加一条评论
I own exactly the same drive (HS16VJX ) and I’m looking for a PCB to salvage data.
@jcarter: it appears you chose @crib’s solution, but it’snot clear wheather it worked for you or not? Did you do as James Yu wrote and replaced the BIOS chip?
Thanks in advance,
Calagan
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jcarter 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 2,604
