跳转到主内容
Repairs guides for the Fender Frontman 15r, a small, 15 watt, practice guitar amplifier. Model number: 022-1500-000.
have frontman 15g.is power switch my problem?
bought used from thrift store. Looks new,but when I turn it on it hums even with all of the dials turned down. And if I plug in my cord it starts popping.I don't know whats wrong exactly.I'm thinking power switch?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
Its MOST likely a loose solder connection somewhere in the unit, maybe on the front panel jack, maybe on the volume pot. It could also be the output IC TDA2050, but usually when those blow they don't sit there humming away afterward, I would suggest looking thru the unit for problems like the ones listed here. http://tetsuoelectronics.wordpress.com/2...
To trace the problem better, take out the amp chassis as shown in the step by step, then with the back PLASTIC end of the screw driver, tap around and see if you get the sound to cut in and out on a specific part of the board, if so its probably your culprit. When I used to fix these a a lot I would just resolder the whole front and back panel as this just guarantees no more issues in the future. Let me know if this works, if not I can walk you thru a few other ideas. Thanks
这个答案有帮助吗?
得分 4
添加一条评论
If the hum is moderate, that is, not at full volume, then it is probably in the power supply. Often a large filter capacitor will break away from the circuit board or go bad.
If the hum is extremely loud, what I would call "scary loud" so that you are compelled to pull the plug immediately, then it could be a shorted diode or output device.
Anyway, it's not the switch, but it still could be easy to fix.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
michael clause 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 155
总计 4,600
