跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
LCD destroyed - Need to figure out what I did.
Working on a glass only, this LCD is gone. I cut the digitizer with the wire. I was wondering, if the problem that is being displayed with this terrible colors and ink like substance underneath is a result of the bad cut. Or if perhaps I over heated the LCD? Or could it be caused by touching the back of the lcd?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
The swirl marks are definitely from me touching the LCD. Once it powered on my first reaction was to play with it. It has the dark color, except for where it is touched.
完成的
Have you tried loosening the screws a little, then triple press home button to get negative screen off?
完成的
添加一条评论
1个答案
已选择的解决方案
etechdavid, looking at the swirl marks on the LCD I go with "a result of the bad cut". Looks to me like you need a new LCD. I'd go with a complete display assembly.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
etechdavid 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 204
