跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
Boots when charger plugged in
Macbook A1181 2.16 GHz
Rebuilt a Macbook as the bottom case was badly damaged. Everything is connected OK, fan magsafe etc.
The issue is when I plug the magsafe in from the macbook being off it boots automatically without touching the power button.
tried resetting PRAM etc but still have the issue.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
Can you take some hires pictures of the damaged case bottom and the area that got the hit so we can see what happened? It sounds like something got damaged case causing a short.
完成的
No damage around magsafe area, damage was superficial and all parts swapped were the ones from before that worked fine.
完成的
Please download and run Coconut battery and let us know your results, Thanks: http://www.coconut-flavour.com/coconutba...
完成的
tried different topcase, checked the sockets, still the same. Then all of a sudden it just started to work normally, no idea why.
完成的
What did Coconut battery show?
完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
When a topcase is not present, a lot of these A1181 boards will power on automatically once connected to power. Is your topcase connected and working? I'd re-seat the connection. If that doesn't do it I'd try a different topcase in order to rule out the original.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
kelvin stephenson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 170
