跳转到主内容
加入维修社区 - 创建账户
Nikon D80 是一款 1020 万像素的数码单镜头相机,于 2005 年公开发布。它主要用于数码照片拍摄和摄像。
FULL message on LCD
I purchased a new Ultra SanDisk 64GB for an upcoming trip. I have formatted the disk, but the LCD on my D80 says "Full" and will not allow me to shoot. If I replace with the current 16 GB disk, everything works OK. What can I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
9条评论
Did you format your new card?
由完成的
The following SD memory cards have been approved for use in the D80 digital SLR. All cards of the designated make and capacity can be used, regardless of speed."
Nikon 512MB, 1GB
SanDisk 64MB, 128MB, 256MB, 512MB, 1GB, 2GB1, 4GB2
Panasonic 64MB, 128MB, 256MB, 512MB, 1GB, 2GB1, 4GB2
Toshiba 64MB, 128MB, 256MB, 512MB, 1GB, 2GB1
All SD memory cards indicated above can be used regardless of their transfer speed.
Lexar Media
256 MB, 512 MB, 1 GB
Platinum II (60x) series: 512 MB, 1 GB
Professional (133x) series: 1 GB, 2 GB1
1 If the memory card will be used with a card reader or other device, the device must support 2-GB SD memory cards.
2 SDHC-compliant.
from https://support.nikonusa.com/app/answers...
So according to Nikon, even your 16GB should not be working;-) try to format and see what you come up with.
由完成的
remove battery from camera and wait about 30 seconds then then replace and all should be ok
由完成的
Thanks @james cleary, it worked.
由完成的
I'm having the same problem, k have a SanDisk 64gb in my d80 and it's formatted to Fat32 and it still says full
由完成的
显示更多的4条评论
添加一条评论
2个答案
最有帮助的答案
Max size of card is 32GB (SDHC)
read more at http://en.wikipedia.org/wiki/Secure_Digi...
这个答案有帮助吗?
得分 3
添加一条评论
There is a good chance the camera doesn't recognize that large of an SD card. Did you try creating a smaller partition on the card? Nikon may have a firmware update but that's an older camera so it may not support that large of a memory card.
这个答案有帮助吗?
得分 1
2条评论:
How might one do that?
由完成的
How do I partition the SD Card?
由完成的
添加一条评论
添加你的答案
Joseph Sharkey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 46
总计 26,611
