跳转到主内容
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 个问题 查看全部
How do I fix my DS Lite wires in the hinge?
Hello, my brother broke my Nintendo DS Lite hinge.In the hinge there is a ribbon wire that is orange and has wires going through it. This ripped and now when I turn on my DS, the bottom screen just flashes and goes back off. Please help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
Guy, check on where the ribbon cable comes from. Use these guides Nintendo DS Lite to disassemble your DS. Post an image of your damaged wire and the location. It is most likely the ribbon cable from the upper LCD. You can repair that by replacing your upper LCD. Here is Here is the guide for that. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
If the ribbon cable is ripped, it is most likely not fixible. If you know of a repair shop that fixes game consoles, ask them. Otherwise, it is probably not replaceable.
这个答案有帮助吗?
得分 0
添加一条评论
open the ds and change the upper screen you can buy the screen at ebay or amazon or you can take an older console and take it out!!!!
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Guy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 24
总计 3,066
