跳转到主内容
加入维修社区 - 创建账户
2012 年中款,A1278 / 2.5 GHz i5 或 2.9 GHz i7 处理器。
Inverter Cable & Inverter Board Location
I just replaced LCD Screen on my MBP. But after I replaced it and reassemble everything, it appears that the backlight doesn't work. I have to point a flashlight at the screen to see. So I think it might have something to do with my inverter cable or inverter itself.
Would someone please tell me where they are so I can proceed on fixing my MBP?
Thank you so much for your time!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
You should have a LED-backlit TFT active-matrix "glossy" display (not an LCD) - which means the controller chip or connector on the logic board is bad. Try an SMC reset.
I would talk with your vendor about why the displays backlight is not working.... examine the cable and connector for burn marks/poor connection.
If you have not connected to an external display do so. If you see no image there you have a bad VGU/VGC or logic board issue. Of course a good image points back to an internal display link problem which is controller chip, connector, cable or LCD screen.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 3
2条评论:
Dude, stop copying and pasting! If you don't have the clue, or haven't dealt with just stop talking in increments. It's so annoying when mammals step in with minimum familiarity. People are searching for help and good advice, not for your poppycock.
由完成的
I found that information to be very helpful. ^^^^^
由完成的
添加一条评论
other answers:
My MacBook Pro turns on, but has a black screen..
https://discussions.apple.com/thread/402...
https://discussions.apple.com/message/30...
iBook screen switches off/goes black when opened more than 45 degrees
screen backlight not working on MacBook Pro
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Khang 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 8,016
