跳转到主内容
The Asus Transformer Pad TF300T is an Android tablet computer released in April 2012. The Asus Transformer design includes an optional docking keyboard that “transforms” the tablet into more of a laptop computer.
Cracked casing, Power Button overly sensitive, random reboot
My TF300 has two issues- the power button issue is the really big problem. Anytime I touch the AREA where the power button is (i.e. the top left of the screen) it decides to turn off or reboot. I am guessing this means the switch itself needs replacing or something. Is that a DIY repair for someone who has done a bit of laptop repair? I have replaced my own hard drive and upgraded RAM- and have been willing to try more complicated things but haven't had the need.
The cracked casing (or backing) may also be contributing to it- you can see cracks especially where the tablet connects to the dock (poor design, IMO). If it isn't practical to replace the backing, anyone have advice to shore it up?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Mine did that. I found that the tape that holds the on/off switch contact moved just a little bit. Pop the back off and look at the tape with a little copper disk at the switch and make sure it is aligned properly. Good luck
这个答案有帮助吗?
得分 2
2条评论:
Thanks!!! Your fix worked for me too! Mine is now working for the first time in about 4 months.
完成的
Thanks !!! That simple fix worked for me as well, driving me crazy and let it sit for almost a year before I found this fix!
完成的
添加一条评论
I had the same problem with my tablet.
Bought at Amazon.fr (dec 2012), the problem with the power button and random reboots appeared after 9 months...
I took photos to help repair.
The little copper disk under the tape must be recentered.
1. the problem
https://pbs.twimg.com/media/BSWouQaCQAAF...
2. the fix
https://pbs.twimg.com/media/BSW5kUGCcAEX...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Lindsay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,477
