跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2396 个问题 查看全部
Why is my backlight out?
i got a new case the other day and the very next day that i had it on i dropped my phone. i drop my phone all the time without a case and nothing happens but i dropped it with a new case on it and my whole screen shattered. they next day i was watching a movie on my couch and dropped my phone onto the hardwood floor. i picked it up and tried to turn it on and the screen would go from black to navy blue but i cant see anything. my phone is still responsive (vibrates when i plug it in, makes sound or vibrates when i get a text/email) but i cant see anything on the screen. what did i do and how can i fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
sadie, "my whole screen shattered" means that you need to replace your display assembly. Here is the guide and the part is available right here. Hope this helps, good luck.
iPhone 4 (GSM/AT&T) Screen图片
产品
$24.99
这个答案有帮助吗?
得分 1
2条评论:
will that fix my back light problem or just my screen?
完成的
the backlight is contained in your display. the power for the backlight comes from some of the components on the logic board. In most case after a drop on the floor, it is the backlight that is damaged. There is always a chance that the components on the logic board are broken, that will be much more difficult to repair.
完成的
添加一条评论
添加你的答案
sadie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 77
