跳转到主内容
加入维修社区 - 创建账户
想自己动手修 iPhone?这里有免费维修指南、原装品质的替换件和专业工具,一应俱全!无论是新款 iPhone 17 系列,还是 2007 年发布的初代 iPhone 2G,iFixit 为所有型号提供免费拆解指南和维修资料!
Hardware diagnostics service software
Hello,
I started a little bit trading with iPhones. Is there any way how can I make hardware check - diagnostics of problems by some software?
And what repair services use when they provide "diagnostics" service.
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 16
3条评论
my iphone 6 shut off just like that and now it only comes on when i plug the cable in, but this the logo come on and then cuts off. i started it up in dfu mode and restored it but its just saying error 4005. what should i do?
完成的
My iPhone 6 Plus has problems, I try and touch the screen sometimes and it doesn’t work, and when I try to download something it shuts off the iPhone and restarts it and all the other iPhones dont have these problems, my iPhone has many more problems to
完成的
@Robin Mason This topic is not what you want to ask.
完成的
添加一条评论
4个答案
已选择的解决方案
radesek, here is my answer to a very similar question:" You could check on here and see if that will help you a bit. "It’s called the iPhone Configuration Utility, which allows you to examine logs from your iPhone or iPod Touch, to apply configuration and provisioning profiles, and more. The tool is very interesting!" from here I believe the software you are thinking of is called "Behavior Scan" More info about it on here and here. I would also like to recommend the iPhone Troubleshooting Guide compiled by one of the users on here. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
6条评论:
Thank you, but I already read this information. The problem is, that I think iPhone Configuration Utility is not exactly what I am looking for and that Behavior Scan somehow cant be accesed without login of Apple employee right?
I need software that will test hardware things like working wifi, camera, jack and stuff like this. Is it possible?
完成的
Can be this a sollution? Problem is I can not be sure with it, since my iphone does not have panicplist entry.
完成的
I do not think that there is any diagnostic software that is available for an end user, that will tell you exactly what is wrong with the iPhone. That would be to easy;-) From what I've read if your phone shows panic.plist. then you may have a hardware error, not very descriptive.
完成的
Where to look for that panic.plist file?
完成的
is there any point having a website with all dead links
完成的
显示更多的1条评论
添加一条评论
Phone doctor plus in the app store, however contact the developer for business solution.
这个答案有帮助吗?
得分 1
添加一条评论
I'm using Battery Health - Your Battery Doctor app in the app store, very nice app
这个答案有帮助吗?
得分 0
添加一条评论
Hello, my company uses NSYS tools. It’s quite easy to use and accessible.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
radesek 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 35
总计 117,781
