跳转到主内容
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
112 个问题 查看全部
My son locked the screen and the device will not recognize login
my son changed the pattern for the screen lock several times and got locked out. now the device will not recognize his user name and password. We logged on to his gmail with the computer so we know the information is correct. is there a way to override the device?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
phillis Bunch, see if this will help. If that does not work, you will have to do a factory reset. REMEMBER that a factory reset will reset your Samsung Galaxy Tab to factory settings and all your data on the device will be erased.
The steps to do a hard reset are as follows:
1. With the device off, press and hold Volume Up and Power button.
2. Release the Power button when you see the Samsung logo, continue to hold Volume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Power to continue. The Galaxy Tab should then go through the hard reset process.
4. When formatting completed, navigate to select Reboot system and press Power. The Samsung Galaxy Tab is back to the factory
Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
Check out the working videos in order to remove pattern unlock
Pattern Unlock Galaxy Tab
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
phillis Bunch 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 605
