跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Display flickers; turns white, backlight stays on. inverter or LVDS
My problem is very similar to the question posted here. It fades to white on occasion while mostly just flickering. It works just fine on an external display. I wanna say its the inverter but i want to be 100% sure before I start buying unnecessary parts. or could it be a loose wire (is it a common occurance)?
serial end:EYA4
MacBook Mid 2007
2.16 Core 2 Duo
Running OS X Lion 10.7.5
3gb memory
MacBook LCD is flickering with some/most angles
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
does this look right:"
2.16 GHz Core 2 Duo (T7400)
Intro Date: May 15, 2007 Disc Date: November 1, 2007
Order No: MB063LL/A Model No: A1181 (EMC 2139)
Subfamily: Mid-2007 Model ID: MacBook2,1
Std RAM: 1 GB Std VRAM: 64 MB
Std Storage: 160 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
完成的
Its doing almost the exact same thing. Only mine isn't quite as bad.like it starts to fade then doesnt. What are the chance that it may just need to be reconnected?
完成的
添加一条评论
2个答案
已选择的解决方案
If the back light is staying on its not the inverter so that suggests the display cable. Try reseating the cable - it may help
MacBook Core 2 Duo Display Data Cable Replacement
这个答案有帮助吗?
得分 2
添加一条评论
when you say " My problem is very similar " is it the same or just similar;-)? It will help if you give a description of what is going on with your MacBook. Fading to white means you are loosing your data from the display, but your backlight stays on. Sounds like the inverter is doing its job. Appears to be more of a display data cable issue...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Nicholas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 499
