How to fix application error 523?
Error 523
Benson, the first thing you want to do is to reload your OS from scratch. Check on here for more information on that. Also, check this answer. Hope this helps, good luck.
这个答案有帮助吗?
their is only a way that i found is
step 1. first of all download the blackberry desktop software 7.0 on your pc and install wherever you want
step 2. then download the blackberry handheld software(remember please see your application version EX. 5.0.0.1036)
step 3. then open your desktop software and connect your phone with no battery or with battery(remember to make a backup of all your data before proceeding)
step 4. click on update and choose your handheld file you downloaded
step 5. then click next and do as according it is said
step 6. wait for some time it would take a longer time for the updation
step 7. when the updation is finished dont unplug your phone from pc
step 8. as your phone reboots wait for the final updation
congo you have successfully updated your device and your problem has been solved
further if this problem occurs hen you can again do these step and solve
IF STILL YOUR PROBLEM PERSIST THEN YOU MUST CONTACT YOUR NEAREST BLACKBERRY CUSTOMER SERVICE CENTER
THANK YOU AND REPLY IF YOUR PROBLEM IS SOLVED OR NOT
这个答案有帮助吗?
My blackberry have this message on the screen,which makes it to fluctuate (You have started a content protection diagnostic tool.Content Protection is not enabled.
BB desktop sofware didnt ask for choose handheld software what to do then i juzt click on update when it shows retry update and cancel i click update then it goes loading then shows no updates are available what to dooo
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 28
总计 70,955
1条评论
Ye kese hoga
由 bablusoni28 完成的 分享
