跳转到主内容
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
power button will not put ipad to sleep
I've got an iPad that I'm fixing the screen on. I've got something bizarre going on that the power button won't put it in or take it out of sleep mode. However, it will power the iPad down. I'm pretty sure I didn't rip the power flex cable. Been down that road before. Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I was able to resolve the issue by turning off the setting for the smart cover. After that it worked like it should.
完成的
添加一条评论
1个答案
已选择的解决方案
Try turning the Smart Cover settings off. If the issue disappeared, then the magnetic sensor is damaged. You can also try the compass, which should also be dead.
If the problem is not caused by the sensor, try restoring the device
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Ethan Grier 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 7
总计 2,184
