跳转到主内容
加入维修社区 - 创建账户
型号A1367,闪存容量:8、16、32及64GB
My screen is cloudy
My ipod got hit from the side and now my screen is cloudy. The screen is not cracked. Do I need to replace the screen or there other way to fix it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Bert, since we can not see what you see, this is just an assumption. If your screen appears milky (washed out) looking, it is most likely that you will have to replace the whole display assembly. Of course you also want to try a restore and check to make sure that your cables are all properly connected. Ultimately so, it does sound like a LCD problem. Follow this guide and the panel is available right here as well as many other places. Hope this helps, good luck.
Replace a front glass screen digitizer compatible with the fourth generation iPod Touch model A1367.图片
产品
iPod touch (4th Gen) Screen
$29.99
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Bert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,658
