跳转到主内容
加入维修社区 - 创建账户
PlayStation 3 Slim是PS3的第二个迭代机型,机器型号CECH-2000。索尼电脑娱乐推出此机型来修复初代“胖机”PS3的诸多硬件问题,于2009年9月1日发布。
PS3 Slim not reading disk
Hey there, I have a PS3 Slim that isn't reading disks. It doesn't display any sort of error, but when I put a disk in nothing happens. Is there any way to find out if I need to replace a control board, the blu-ray drive, or just a cable?
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 12
13条评论
Does it read any disk, or none? Tried a CD, DVD and game disk?
完成的
No disks at all.
完成的
u need a new dick reader my ps3 slim is wors i caint even tak my fave move out so i ttok it a part and moded it it took like 2 hours thats it it helps when uk what u r doing
完成的
it wont let me do it either
完成的
it reads dvd's for like movies but it barely can read game disc's
完成的
显示更多的8条评论
添加一条评论
4个答案
已选择的解决方案
The ps3 slim has dual lasers on the deck. One is for DVD's and the other is for Blu-rays. If the PS3 plays DVD's and not games. Your Blu-ray laser is out or not powerful enough anymore to transfer data.
If you get No DVD or Game loading or playing. Your Laser most likely went out.
I have fixed over 5k ps3 systems. please DO NOT attempt it yourself. there are alot of springs and switches that need to line up perfectly to get it back together.
Although the PS3 slim can be troubleshooted easily if you have some experience with tools.
Open the PS3 using the proper tools.
Remove the Power supply by unscrewing the screw on either side.
If your look at the DVD Drive. If you have a cable to the far left. That's an easy one. Stay away from the one with the 3 ribbon cables in the back. Headache for you.
If you have already decided you should open it anyway or have the easy one read further.
After removing the top of the DVD (Metal Cover) take off the DVD Spindle Top. (White Round Thing)
Find a Blank DVD or Cd carousel. At the bottom is a clear cd/dvd. You can load this into the ps3 and see thru it for the lasers.
Once you put the clear cd/dvd in the ps3 (leave the spindle off) you will see the laser move forward and try to read. Blu laser will fire first. then red.
If you see both lasers then you have gotten 50% of your answer. At this point you should not have taken any screws out of the dvd drive other than the top one to get the cover off.
Use a q-tip and a little alcohol to clean the lens of each laser then replace the spindle top and try a game. If you cannot at this point play a game your laser is bad AND HAS TO BE REPLACED.
这个答案有帮助吗?
得分 5
添加一条评论
To those who change the lazer and it still doesnt work. Try putting the disc in the drive and taking it out again straight away. Repeat up to 20 times. I spent a whole afternoon trying to get a new lazer to work and thats what did it. Apparently they need to have a bit of power run through them first. Shout out to the people having this problem in 2016 took me 3 days of google searches and still found the answer on my owb pretty much.
这个答案有帮助吗?
得分 5
1条评论:
Having this problem in 2023!
完成的
添加一条评论
Maybe try a new connector cable?
这个答案有帮助吗?
得分 0
添加一条评论
id say try a new cable or reattach your current cable since it could have been knocked loose or loosened on its own over time, if that doesn’t work then do a through check on all cables without damaging anything, try one more time then if it still doesn’t work then it might be the disk reader
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Adam 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 58
过去 30 天: 249
总计 65,897
