跳转到主内容
加入维修社区 - 创建账户
2010年4月发布 / 2.4、2.53 GHz Core i5 或 2.66 GHz Core i7 处理器
MacBook Pro is just dead
My Macbook Pro does not start (boot) anymore, no sign of life at all.
What I tried so far:
1. pressing the power on button in various combinations with the cmd, ctrl and shift buttons (as suggested on some websites)
2. removed the battery, pressed the start button for at least 10 seconds and replaced the battery
3. removed the battery and tried to start without battery (but with the battery charger connected)
Doing a battery check (pushbutton at the left side) rusults is no leds lighting when the battery charger is disconnected and all leds lighting when the battery charger is connected.
Any help is appreciated,
Rik
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
2条评论
A history of the machine might help.
完成的
the macbook worked fine for years, some days ago I left it in working order, when I returned one hour later it was dead.
完成的
添加一条评论
3个答案
已选择的解决方案
Knowing the exact year/model would assist us with getting specific info for you.
Check the power adapter voltage with a meter. Perhaps it has failed.
Can you borrow another adapter or charge the battery in another MacBook ?
这个答案有帮助吗?
得分 4
25条评论:
I tried another adaptor without any result.
The model is A1286, year 2010.
完成的
Rik. Thanks for accepting my answer but its a little premature if you are not up and running. Now I have the model no ill see if I can't give you more specific advice. Are you willing to put your Mac apart to investigate?
完成的
Ok, I "unaccepted" the answer.
As long as it can be reversed I am willing to disassemble the Macbook.
Thanks, Rik
完成的
do you have a multi meter or can you borrow one?
完成的
yes, I have a multimeter
完成的
显示更多的20条评论
添加一条评论
Did your MagSafe only light up with a dim green light?
Mine shows only a dim green light with the battery in or just the AC. The battery lights are all off. Do you think your fix would work in my case?
这个答案有帮助吗?
得分 3
1条评论:
I had no LEDs lighting when running only on battery and all LEDs lighting when running on the AC power supply.
But if you have the screwdrivers, the resistor and a voltmeter at hand it takes less than half an hour to try it.
完成的
添加一条评论
Anyone else in this situation can try this, to verify if the battery is the culprit (on older Mac models with removable battery):
https://osxdaily.com/2019/06/14/how-boot...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 4,068
