跳转到主内容
Introduced by Toshiba in 1997. It measures only 210 x 115 x 34 mm. It supports Windows 95 and comes with a 75 MHz Pentium processor, 6.1" TFT screen, 810 megabytes hard disk capacity.
1 个问题 查看全部
Screen has colored lines when windows loads
When I turn on my Libretto 50CT it goes through the set up normally but as soon as the 'Windows 95 is loading' the while screen has red and blue colored lines through the whole screen. What can I do to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Do those lines show up in every mode, like safemode etc? also, have you tried to change the settings for your resolution? It is possible that this is a faulty LCD (Tab errors on the panel itself). If it is your LCD, then it may get a bit expensive. The part number is P000236950 and the cheapest one I found (granted, a quick search ) is around $100. you may consider keeping your eyes open at ebay.com or other places.
完成的
@oldturkey03 yes it happens in safe mode. I will try changing the resolution to see what happens. Thanks!
完成的
添加一条评论
1个答案
已选择的解决方案
Zach Pinoni, since it happens in every mode, it does sound like a bad LCD panel. It is a neat little vintage machine, and I would definitely try to get a LCD for it. Besides this great guide I also added the service manual and the parts list for this computer on here. Just scroll down to "documents" and click on the links. It should help you to replace the panel. Do let us know how it turns out. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
3条评论:
Thanks for the guide, however I do feel that $100 is a little over priced to pay for such an old device that has not much use anymore. Thanks again!
完成的
Don't give up on it yet. keep it at least for a while and lets see what we can dig up. What do you think would be acceptable $$wise for a LCD?
完成的
Im not sure about the price on this machine, but if it was Apple id know haha but Id say Id be willing to spend $50 maybe 60/65 on it at the most.
完成的
添加一条评论
添加你的答案
Zach Pinoni 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 10
总计 792
