Screen has colored lines when windows loads
When I turn on my Libretto 50CT it goes through the set up normally but as soon as the 'Windows 95 is loading' the while screen has red and blue colored lines through the whole screen. What can I do to fix this?
2条评论
Do those lines show up in every mode, like safemode etc? also, have you tried to change the settings for your resolution? It is possible that this is a faulty LCD (Tab errors on the panel itself). If it is your LCD, then it may get a bit expensive. The part number is P000236950 and the cheapest one I found (granted, a quick search ) is around $100. you may consider keeping your eyes open at ebay.com or other places.
由 oldturkey03 完成的
@oldturkey03 yes it happens in safe mode. I will try changing the resolution to see what happens. Thanks!
由 Zach Pinoni 完成的
