跳转到主内容
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 个问题 查看全部
Screen has green and pink lines and "snow"?
Screen has green and pink lines and "snow". When it boots to the apple logo it will have green and pink lines down it and IF it boots past that none of the applications will show up it will just be a blank blue screen or desktop with the pink and green snow and eventually it will go out. What do I need to do to fix this, what parts and what tools do I need? Thank you so much for your help!
Update (05/12/2013)
Just for clarification, it is a 27" iMac Late 2009 i5 2.66 GHz, 1 TB Harddrive.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
已选择的解决方案
David, what Dan is trying to do, is to determine if it is your video card/circuit or your LCD. So the best and quickest way is by attaching an external monitor. Here is what Apple says about your symptoms:"
Quick Check
Symptoms Quick Check
Vertical/Horizontal Lines
• Vertical lines
• Horizontal lines
1. Boot from install DVD to determine if potential software issue exists.
2. Verify if issue is visible on an external display.
Deep Dive
1. Boot from Install DVD and verify if issue is still visible:
• Flickering image
• Horizontal bands of static intermittently appear
• Dock and / or menu bar shift positions
• Display intermittently flashes on / off
Yes--> Go to Flickering issue, go to Noise / Unstable Flickering.
No--> Issue likely caused by software or driver issue. Troubleshoot for software
issues. Make sure all software updates have been installed.
2. Verify if issue is visible on an external display attached to mini DisplayPort.
Yes--> Issue NOT caused by internal LCD. For systems with a video card, go to step 3. For systems without a video card, go to step 4.
No--> Go to step 6.
3. If a video card is present, remove video card and inspect connector for damage or corrosion then reinstall. Verify if issue still occurs.
Yes--> Replace video card.
No--> Issue likely caused by poor video card connection.
4. For systems without video card,horizontal lines may be related to a failing RAM module. Verify if video issue only happens AFTER Apple logo and spinning wheel appear.
Yes--> Issue only happens AFTER Apple logo and spinning wheel appear. Go to step 5.
No--> Issue present before Apple logo and spinning wheel appear. Go to step 8.
5. Start with shift key down (safe mode) to disable system extensions. Verify if issue still
happens when booting in safe mode.
Yes--> Go to step 8.
No--> No video issue when booting in safe mode. Go to step 6.
6. Isolate with only one memory module installed, then with the other one. Test with knowngood
memory. Verify if issue only happens with specific RAM module(s).
Yes--> Replace affected RAM module.
No--> Go to step 7.
7. Isolate with one known-good memory module installed in one memory slot. Repeat by testing in other memory slots Verify if issue only happens with specific memory slot of logic board.
Yes--> Replace logic board and retest.
No--> Go to step 8.
8. Disconnect DisplayPort cable between LCD display and logic board, and verify if there is damage to cable or connectors.Repeat with vertical sync cable connected between LCD panel and LED backlight board.
Yes--> Replace DisplayPort cable and vertical sync cable or any other damaged part/module.
Go to step 9.
No--> Reinstall DisplayPort cable and vertical sync cable.
Go to step 9.
9. Verify if issue is still present after reinstalling internal DisplayPort cable and vertical sync cable.
Yes--> Replace logic board. If video card was present, reinstall original video card.
Go to step 10.
No--> Issue resolved.
10. Verify if issue is still present with replacement logic board installed.
Yes--> Go to step 11.
11. Reinstall original logic board and verify if issue is still present with original logic board reinstalled.
Yes--> Replace LCD panel. Run Apple Service Display Utility.to verify the resolution of intermittent display flickering symptoms.
No--> Issue resolved. If a video card was present, reinstall original video card."
So, I strongly advice that you follow Dan's way of doing things. Good luck.
这个答案有帮助吗?
得分 3
5条评论:
Thanks OT! ;-}
完成的
Where can i get the GPU and Display? I have the money and would just rather go ahead and replace both of them.
完成的
For a proper identification you really should give us the last three of your serial number. I still think you should follow Dan's advice, there might be no reason to replace all of it at once. After all, you are looking at around $600 for parts alone. According to the manual, the video card used is a ATI Radeon HD 4670, 256MB part number 661-5314. The LCD assembly has the part number 661-5527. As for where you can get it, that depends on where you are located.
完成的
Alright, I hooked the iMac up to an external display and nothing would show up, like I said half of the time, the desktop will not even show up. And I could not do anything on the mac to try to fix this issue. The last three of the serial are: 5PJ. If I need to replace anything, the harddrive, the GPU, or the display, I will need a link as to where to find them, because I live somewhere where we don't have many computer repair places.
完成的
Replacing the GPU card on a 27" iMac is one of the most difficult, time consuming and entertaining repairs... If you can do this, you can do almost anything.
完成的
添加一条评论
David - It sounds like either the display or GPU is failing. To help isolate out which can you connect an external monitor to your system. Does the display on it look OK? If it does then you know the display is having problems otherwise the GPU. Let us know what you find out.
As to the needed tools the iFixIt tool kit should meet your needs here Pro Tech Toolkit and a set of suction cups Heavy Duty Suction Cups and lastly, an ESD mat & wrist strap Anti Static Mat
Heavy-Duty Suction Cups (Pair)图片
产品
$14.95
Anti-Static Mat图片
产品
Anti-Static Mat
$24.99
这个答案有帮助吗?
得分 1
5条评论:
Where could I get the display or GPU from? I would rather buy them separately and repair it myself than to take it to apple. I am unable to hook it up to an external monitor at this time.
完成的
Well the display looks fine, I have already taken off the cover and the screen itself seems to be fine so where and how can I replace the GPU?
完成的
So you connected an external monitor to your system so see if that display worked Vs your internal one. If you did was it showing your desktop and the icons you would see on your internal?
完成的
OK - So the External monitor does not show anything when the internal display goes out (when the internal IS working the external also is working but is showing the same green & pink stripes). That means the GPU is gone. You can follow this guide on how to replace it GPU Upgrade.
完成的
添加一条评论
I had the same issue with my iMac 27 Mid 2010. Pink and green squares all over the screen. Threw my GPU in the oven 400f degrees for 9 mins. Problem solved.
这个答案有帮助吗?
得分 0
1条评论:
Norwegian: Bytt termisk pasta på prosessor og grafikkkort
English: Replace thermal paste on processor and graphics card
完成的
添加一条评论
MY SOLUTION (working):
I was able to recover my iMac 27" graphic card by open the computer and applying an electronic Contact Cleaner (I used M500 from BASTON.com.br), but there are many brands out there. I really didn't disconnected any inside cable, I just carefully pull up the display for at least to be able to see inside, since there are short and fragilely connected cables. I've followed ifix.com repair guide for this repair, but I didn't make all steps, again, I've just removed the eight T10 Torx screws securing the LCD to the outer case (to remove these screws I've used a standard screwdriver, without any trouble, despite the magnets attracting the tool and the screws. To put the screws back, I've needed to use two screwdrivers to position the screw correctly). Then, after shaking the product, I've applied the Contact Cleaner, from both sides, and from the top. Then, I left the computer alone for 20min. And finally, it has worked as it was new. Of course, ALL THIS SIMPLE PROCESS YOU NEED TO DO WITH THE ELECTRICITY CABEL DISCONNECTED. These cleaners are inflammable.
So, I didn't need to replace the graphic card, so I don't know if the cleaner has fixed some soldering connection, or if it was the dusty problem. Really, it has a lot of dusty inside, I have this iMac since 2009. But, really I din't cleaned it up properly, since I was afraid to disconnect the cables. I just applied the Cleaner, and it is working fine now. I reboot the imac again and again, and it boots perfectly now.
这个答案有帮助吗?
得分 -1
7条评论:
Most likely you just cleaned out the dust which helped here. Most electrical cleaners have oil in them that over time collect dust! Take a mirror or piece of glass and spray a little on it, let it dry if it leaves a film don't use it! All you do here is make a very big mess as you'll need to completely wash down everything with a solvent to remove the oil.
完成的
Dan, thank you for your hint! I did the test right now, and the liquid evaporates completely in a few seconds. So I have luck here, since I didn't know the risk I was taking. Thanks to share!
完成的
You are very lucky! I had a customer spray a full can of contact cleaner into their laptop cleaning out the keyboard after she spilled a drink into it. She was so proud she fixed the problem on her own, but a few months later she handed me her system crying as it had completely died. After I opened it up I told her the news I couldn't fix it as it was just to much work to clean out all of the oil and the dust it had collected and fix the now damaged keyboard.
完成的
In the end this is not a nice result, indeed. My computer still has too much dust inside. I didin't cleaned up because i can not afford a repair at the moment, and I was afraid to disconnect the display cables. But, I hope my computer can work a few more months, then I'll definitely take it to a repair service, even knowing that it could be more difficult to repair later on.
The question for me is the moment right now. IPhone 6S is comming, and this next investment has been already planned (I'll replace my old iPhone 4S). After this acquisition I'll target my iMac revision repair. Thanks for your hint!
完成的
Hi:
I have this problem too. Is your iMac still working after all these months? Thanks.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
David Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 13
总计 42,620
