简介
如果您正在使用iMac 27“2009年末或2010年机型来玩游戏,那么您可能希望将显卡升级到2011年型号的Radeon 6系列显卡。
你所需要的
要重新组装您的设备,请按照本指南的相反顺序进行操作。
101等其他人完成本指南。
由衷感谢以下译者:
30%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
128指南评论
Did you know you can add an additional SSD drive WITHOUT needing to remove your Optical drive? It installs vertically just to the right of your HDD. I just performed this upgrade last weekend. I believe you can do this to 2009 and up models.
bistroengine - 回复 分享
Regretfully Not on the iMac late 2009, because the motherboard has only 2 SATA ports, not 3 like the 2010 and later models...
Just a question: with this mod, are you able to use Airplay Mirroring in Mountain Lion? Since the inhability to use it on these macs is GPU-related, virtually with this Graphic card you may be able to enable it... Let me know please!!
