My screen is on but the not responsive
I changed a cracked, the ipod powers up with picture but the screen will not respond.
nathanlinville, double check your work to make sure your connectors are properly seated. If the connector is okay, properly seated and no bend or broken pins, I would replace the assembly once more for a new one. If you find that the assembly is working, just not in your iPod, you may have a faulty touch screen controller on the logic board. Check for missing, charred or broken parts on the board. Hope this helps, good luck.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 156
