跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
My screen is on but the not responsive
I changed a cracked, the ipod powers up with picture but the screen will not respond.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
nathanlinville, double check your work to make sure your connectors are properly seated. If the connector is okay, properly seated and no bend or broken pins, I would replace the assembly once more for a new one. If you find that the assembly is working, just not in your iPod, you may have a faulty touch screen controller on the logic board. Check for missing, charred or broken parts on the board. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
nathanlinville 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 163
